car wont start/fuel relay harness HELP
Old Feb 20, 2001 | 06:38 PM
speedlvr's Avatar
I was testing the fuel relay harness for battery voltage and it DID have voltage. Then I tried to actuate the fuel pump by jumping the harness and I touched the wrong connection evidently. It sparked and now the car won't start and there is NO battery voltage to the harness. All the fuses in the fuse block appear to be good still. What the hell could have happened? Thanks.
Old Feb 20, 2001 | 09:30 PM
Andy89RS's Avatar
Check the fuse near the battery. The location of that fuse is a recent subject on the tech board. This shows a Firebird engine compartment, but if you imagine that the front of this car is the right fender, it will work for a Camaro, it's in the same position relative to the battery
[This message has been edited by Andy89RS (edited February 20, 2001).]
Old Feb 20, 2001 | 10:25 PM
racer J's Avatar
Car: 1992 Chevrolet RS Camaro
Engine: 305 TBI
Transmission: WC T5 conversion
Axle/Gears: Debatable . . .
Actually my battery is on the right side of my Camaro. The fuse up near the battery is for the ecm memory but if the fuse is blown it will also keep the car from starting.
1988 Camaro
305 bored .030 over
Stock TBI
Aluminum radiator
No smog pump
gutted factor cleaner
cam ground to crane specs
timing advanced 9 degrees
no thermostat
other than that its bone stock and ran a 16.4 @ 82 mph with earth shattering wheel hop and a 2.88 60 ft time. (this was with the rebuild and cam only)
Old Feb 20, 2001 | 11:08 PM
Andy89RS's Avatar
The fuse is for more than just ECM memory, it's also fuel pump and injectors. Camaros all have the battery on the right side, that's why is said to imagine the front (top of picture)of the pictured car as the right fender of the Camaro...
Old Feb 21, 2001 | 12:28 AM
speedlvr's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Andy89RS:
</font>
Andy,
You KICK *** ! Thanks a million!!!!
Old Feb 21, 2001 | 12:41 AM
racer J's Avatar
Engine: 305 TBI
LOL duh wth was I thinking! For some reason I thought you Firebird's pic showed it on the right side. Thanks for the info though cause I didn't know that fuse also was related to the fuel system.
1988 Camaro
305 bored .030 over
Stock TBI
Aluminum radiator
No smog pump
no thermostat
Old Feb 21, 2001 | 12:49 PM
FRMULA's Avatar
Funny, my '88 Formula has the battery on the passenger side (right) fender since New. My Cruise control assembly used to be on the drivers side.
What do they say about a picture being worth a thousand words. Judging from the overspray on the hood bumpers I would say that this car had some serious front end repair work done to it.
Jorlain
Aug 24, 2022 05:11 PM
RazorN8
Jan 7, 2022 11:44 AM
midge54
Sep 2, 2020 07:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
jharrison5
Aug 19, 2015 05:53 PM
