failed emmisions...help?
Old Dec 31, 2000 | 12:51 AM
mike ghoul's Avatar
i just failed the VA emissions test. My car read almost double the legal limit of NO.
does anybody have any idea what the problem might be. All non emmisions legal parts had been removed for the test, but i had my AFPR set at 15 psi.
I'm thinking that could be the problem or possibly a bad egr valve.
any help would be appreciated.
1990 Camaro RS
305 TBI Auto
K&N Open Air Element, Edelbrock Performer Intake, Edelbrock Headers,Catco Hi Flow Cat, Edelbrock Exhaust, Hypertech Underdrive Pulley's, Jacobs Ignition, Fast Chip PROM, B&M Shift Kit, B&M Mega Shifter, 3.73 Rear with Auburn Limited Slip, KYB GR2 Gas Shocks and Struts, Eibach Pro Kit Lowering Springs, Edelbrock 3 Point Strut Tower Brace, Baer 13 in. Slotted Rotors with Metallic Pads, American Racing Torq Thrust II 16x8 Wheels with Toyo 245 50 VR 16 Tires, 3 in. Cowl Hood, A little weight here and a little weight there.
Old Dec 31, 2000 | 11:33 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
The fuel pressure is way too high
Old Jan 1, 2001 | 12:01 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Might be an EGR problem or a cat. flowing to much. Remember they have a positive pressure EGR, without some back pressure they don't work right. Could also be the EGR solenoid some times they get stuck and need cleaning.
Chronologically challenged. But still alive!
92 CAMARO RS
305 TBI 5/spd (now TPI)
'69 camaro
BB/Lenco
1050 dominators
8.97-150+
Pump gas/no drugs
Old Feb 6, 2001 | 01:43 AM
mike ghoul's Avatar
well thanks for the advice(been busy the last several weeks, that's why this is so long in coming)
turns out I had a bunch of problems, the fuel pressure was fine, but my egr solenoid was fried, and the insides of my cat were busted up, also the AIR tube was completely bent and non functioning. got it all fixed, and had the cat tucked up a little bit, and she passed easy(better than when i got it 2 years ago by far!)
later....can't wait till track opens.
Old Feb 14, 2001 | 05:44 PM
88firebirdTBI's Avatar
it has to eb your egr valve.does your camaro read any trouble codes? Defiantly check the egr.i dont think it is the cat.
Old Feb 15, 2001 | 12:30 AM
SHARP89RS's Avatar
It's the EGR valve most likely how old is your cat converter?
John Too many Mods !
[This message has been edited by SHARP89RS (edited February 14, 2001).]
Old Feb 22, 2001 | 12:59 AM
mike ghoul's Avatar
the cat was only about 2 yrs old, but i crunched it and the air tube on some speed bumps, cause the car is lowered, and i got some fat assed friends.. ha ha. anyhow it's running good now, i'm planning on taking it across the country this summer. to CA then back. hope it makes it.
1990 Camaro RS
305 TBI Auto
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
racereese
Oct 3, 2015 03:46 PM
6998poncho
Sep 25, 2015 02:56 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
