injector spacers. Worth it?
Old Feb 28, 2001 | 04:50 PM
Andys92RS's Avatar
I am going to do the Ult. TBI mods. I wasn't going to do anything until i build my 383 but i can't stand it. How neccessary is injector spacer. I only ask because I don't have the facilities at the moment to make my own, so I would have to purchase one. Turbo City want $20 for one. Thats rediculus for a tiny peice of plastic(I read someone had a bad experience with them).
My second question is this. A friend of mine is machining me a throttle body spacer. I am going to make it 1" thick, made of aluminum (phenolic resin is scarce at work, Uncle Sam is paying for it, so I can't complain). Since the space ring is about 1" wide, if I ditch it, and use a drop base 3 or 4" inch air cleaner, I shouldn't have any problems right. Also should I have it machoined with a 1 11/16" holes, as to use with a larger TBI adapter. Or, Should I have him machine it for the stco 305 size holes. Or, machined so it goes from one size to another. I now this is alot, but I'm beating my head in trying to make the decision before I spend the cash.
Old Feb 28, 2001 | 04:56 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
drop base without spacer will hit linkage.
305 is 1 11/16, have him bore it from stock on the bottom to 2" on the top, that way if you every want to get a bigger tbi you can.
[This message has been edited by snflupigus (edited February 28, 2001).]
Old Feb 28, 2001 | 05:09 PM
Andys92RS's Avatar
Thanks for the heads up with the drop base.
Your right about 305 holes, my bad. my thinking was that having larger holes all the way through would make a little turbulance at the transtion between the TBI and the spacer. But, I geuss it doesn't happen with other adapters (ie. carb), so why would it for that. I plan on changing the intake anyway, so I think i'll go the whole way. Geuss I'll have to do the cam to, wifes gonna kill me.
what about the injector spacer?
Old Feb 28, 2001 | 06:14 PM
NJ SPEEDER's Avatar
there i s a gasket beneath the injector tower, go to a parts sftore and get 2 of them. for less than 3 bucks prolly you can have the same thing, just not as flashy.
lata
tim
91 Camaro RS-LO3,Auto.
14.215@94.30 w/ 1.917 60'
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Keiffer76
Sep 9, 2015 08:52 PM
