New Holley Injectors
Old Mar 7, 2001 | 04:38 AM
Dan W's Avatar
As many may have heard, Holley injectors may have problems handling fuel pressures above 17-18 PSI.
I had the chance to assist in a 2bbl Holley TBI kit install (from howell-efi)the other day and noticed that the style of the injectors have changed. I dont know if they corrected all of their problems as the only real visual cue is the difference in the way the wiring harness plugs into the injectors. They now use a sort of weather pack connector (like the rest of the plugs on our cars) instead of the old cap style plugs.
1988 T/A,
9" Ford, 3.50 gears, Auburn posi, 700r4 -w- 2100 converter
350 .060 over with forged 1 pc rms crank, and forged TRW pistons, 9.5:1 cr
Factory GM heads Pocket ported, 2.02/1.60 valves, back cut
Lunati roller 219/227, .479/.480, 112 LSA
Holley 700cfm 4bbl on TBI truck 7747 computer and chip by Howell-EFI
Edelbrock Performer EGR intake, Edelbrock TES and 3" cat
Old Mar 7, 2001 | 04:46 AM
Tas's Avatar
Tas
cool. Your engine is 5.9L? thats awesome. Is it true .060 over engines have cooling problems or is that a myth?
-Tas
'89 Formula WS-6
[soon to be Torch Red with black hood and headlights =) ]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz | ICQ 82881207
Old Mar 7, 2001 | 10:50 AM
Dan W's Avatar
Its 360 ci. Havent had any cooling problems.
Old Mar 7, 2001 | 03:30 PM
Birmass's Avatar
You shouldn't have cooling problems. The problem is that if you let it overheat the block is a lot more likely to crack if you have thinner cylinder walls.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
All your base are belong to us.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
webeeZ28
Sep 14, 2015 12:00 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
