Im at my whits end with this damn 350 tbi swap!!
Old Mar 8, 2001 | 01:35 PM
Maltese's Avatar
I did the swap about 5 monthes ago and at x mas i got a got custom burned chip and it ran great up until here recenly. i have the 350 injectors and afpr. i checked the plugs and wires and the plugs are browna dn the wires appear to be fine they are about 2 years old. but my problem is that the thing feels like it has a dead a$$ miss. i can't figure it out. it only does it when i give it more than half throttle but when i put it on first gear and romp it from about 3000 rpm it doesn't do it. what the heck could be by problem. it seems to me like the computer is screwing it up but i have that chip to fix it and it was fixed up until here recently. could it be that the warmer weather is causing it to run lean and i need to bump up the fuel pressure? thanks
Old Mar 8, 2001 | 01:40 PM
FastBroker's Avatar
Did you check for error codes, yet???
Old Mar 8, 2001 | 01:44 PM
Tas's Avatar
Tas
do you still have the 305 knock sensor in there? is it a flat tappet hydraulic cam or a hydraulic roller cam? Is the distributer in the right tooth? Is the cat clogged
-Tas
'89 Formula WS-6
[soon to be Torch Red with black hood and headlights =) ]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz | ICQ 82881207
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
