O.k. Engine advice time
Old Mar 9, 2001 | 11:52 AM
81Z28's Avatar
I'm about to drop a 350 in my 91 RS in place of the now 151,000+ 305. The 350 is stock except it has Hooker shorty headers. What would be a good pair of heads and a good cam. Also, what about a diff TBI? Would I have to get the computer reprogrammed? OR what about adding a chip and what kind. Thanks everyone!!
Greg
'91 RS
'81 Z28 (in storage)
Old Mar 9, 2001 | 10:21 PM
The ODB's Avatar
the 305 heads you have might be good if they are the same as the TPI high output heads. They would just need to be ported good and get some screw-in studs & guideplates, plus a 3 angle valve job & blending.
I would recommend the camshaft and rockers that I run. You will need aftermarket lifters & hardened pushrods of the proper length (to be determined after assembly).
You can find info on bigger throttle-bodies on this board. I recommend running the biggest you can get along with a good aftermarket intake like an Edlebrock-RPM.
*I do custom performance mods on Edlebrock Performer carburetors (dualplane intake mods in the works),
White 1986 Irocz, 305 with iron #416 heads,
383 with aluminum TFS heads,
Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, Vigilante 2400 lockup converter, 3.25:1 Ford 9" rear, Mcreary Road-Stars, SLP-stainless 1.75" shortie headers & Y-pipe, single 3" Borla exhaust, Linginfelter-TPI camshaft part number 74216 pulls 17" vacuum solid. Cam specs 213/219 @.050 114-LSA, sometimes advertised at 216/219 @.050 112-LSA .462/.470 lift @1.5:1 ratio. Using Harland Sharp 1.65:1 roller rockers. MSD-6AL, billet distributor, multi-retard, blaster-3 coil, and RPM switch. SouthSide machine subframe connectors, SSM lift-bars, Moroso 4" underdrive crank pulley.
N/A runs 10.9 @124,
Crack-runs 10.3 @135
haven't run at track since Oct-99
* vizit miy homepayge * http://www.geocities.com/trailerparkpage/
theshackle
Mar 5, 2017 06:37 PM
dutch930
Sep 11, 2015 06:58 AM
justin57
Aug 20, 2015 07:05 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
