tbi injectors
Old Jan 19, 2007 | 07:12 AM
ryan77's Avatar
Car: 89 Camaro, 00Xtreme s-10, 89 Buick "Party Ave"
Engine: 305tbi
Transmission: 700r
tbi injectors
how do the 2 injectors actually come out, do they just push out...or screw out...I took my tbi apart for a rebuild...removed allens...removed top peice(pressure reg.) and the peice that holds the injectors(where the fuel lines hook up to)and thats the only thing I havent un-assembled yet...I don't want to force it untill I know excatly how they come out...this car has sat for 7 years and is gummed up...
Old Jan 19, 2007 | 11:04 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Basically they pull straight out the top. Once the top cover is off place a metal rod such as a phillips head screwdriver shank across the top of the pod. Now with a straight blade screwdriver using the round rod as a fulcrum point, pry the injector upward. For an injector pry point place the blade under the center post.
RBob.
Old Jan 23, 2007 | 01:18 PM
ryan77's Avatar
Engine: 305tbi
Transmission: 700r
nice tip...thanx....worked like a charm.
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
BAMiller
Sep 14, 2015 06:38 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
