HELP NOW PLEASE!!!!!!!!!!!!!!!
Car: 87 Z28
I changed my plug wires and cap and rotor and my car idles rough and when its in gear idles REALLY rough and feel kinda like its gonna stall.. what could the problem be.
You probably mixed up two of the plug wires.
1988 T/A,
9" Ford, 3.50 gears, Auburn posi, 700r4 -w- 2100 converter
350 .060 over with forged 1 pc rms crank, and forged TRW pistons, 9.5:1 cr
Factory GM heads Pocket ported, 2.02/1.60 valves, back cut
Lunati roller 219/227, .479/.480, 112 LSA
Holley 700cfm 4bbl on TBI truck 7747 computer and chip by Howell-EFI
Edelbrock Performer EGR intake, Edelbrock TES and 3" cat
1988 T/A,
I thought I told you to take off one wire at a time and then put it back on with the new one so you wouldnt mix up the wires. Now you have to go back and make sure every wire is in its correct place. The firing order is 1-8-4-3-6-5-7-2. plugs 1-3-5-7 on the left and 2-4-6-8 on the right. Instant message me again later and ill try to help you out.
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Yeah, look on the intake manifold for the firing numbers for the engine block. They will be engraved on the intake. And the firing order on the dist. cap goes like what Tom (COBRA) said.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
Car: 87 Z28
Damn im almost positive i didnt mix em up.. the firing order is right on the front and im almost sure i got it right.. ill double check later and one of u guys be on aim
