Is anyone having problems with their MSD?
Old Mar 20, 2001 | 09:50 PM
EROCK's Avatar
I am not even sure that the problem is my MSD 6A. When my car is cold, it will not run properly and misses something fierce. Seems like it only does it under 2,000 rpm. I tried everything else except my 6a. Maybe it is not firing right uynder 2,000? Anyone have a cold problem with theirs? Thought it might be the 6A because under something like 2,000 doesn't it fire the plug like three times or something? Possible malfunction? I am getting no SES light or anything and all gauges are normaly set. Once the car is warm it squats and lifts the front and takes off. When it is cold and under 2,000 it just spits and sputters. Any help or feedback would be greatly aprecitaed. Thanks guys
Eric
Teal 1991 Camaro R.S., T-Tops,
Leather, Re-worked 700r4 also w/kit,
MSD ignition, MSD 8.5 mm. superconductor wires,
MSD Coil, ADS superchip, Open element air cleaner,
K-n-N filter, Gutted cat, Flowmaster cat-back system,
Edelbrock TES headers, March 3piece billet underdrive pulleys
3.73 gears
http://www.geocities.com/gitarz2/camaro.html
I was shocked to see that companies sold a taillight
set for a rustang! Since when do they have taillights????
Old Mar 20, 2001 | 09:58 PM
Tas's Avatar
Tas
It looks like Andy89RS's MSD made his cap and roter prematurely wear from the amplification effect of the MSD. Check your cap and roter.
-Tas
'89 Formula WS-6
[soon to have Hooker 1-5/8" 50 state legal headers installed]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
Old Mar 20, 2001 | 10:03 PM
EROCK's Avatar
O.K. I will. Good idea. Would it do it only when it is cold though? If it were the cap and rotor wouldn't it do it all the time? Just curious. Thanks again for the idea.
Eric
Old Mar 20, 2001 | 10:05 PM
EROCK's Avatar
Taz,
By the way, where did you get your non-drop base for your air cleaner? Been looking everywhere. Thanks
Eric
Old Mar 21, 2001 | 10:03 AM
9177's Avatar
I've had my system for 2 years now and no problems with the system. It is most likely your open air element. I just put mine on 3months ago and my car does the same thing as yours. let me guess still below 50 there at night.
Old Mar 21, 2001 | 03:42 PM
EROCK's Avatar
Yes. Under 50. Open element air cleaner. Been that way for 3 years. Why is it just now a problem? I have driven it this last month when the temp was about 10 below 0. No problems. Fired right up, drove right off. Never has in 3 years. Last week there was a 70 degree day and it did it in the middle of the afternoon. Just always does it when there is a cold start. If it sits for more than 3 hours or so.
Eric
Old Mar 21, 2001 | 05:58 PM
Tas's Avatar
Tas
I got mine from P.A.W. $17 with paper filter. I got a K&N after I tested with different paper elements to see how high I could go. I needed a longer "carb" stud because the top of the open element is not flat like some models. The top is slightly coned and looks great. www.pawengineparts.com
1-818-678-3000
818 is northern Los Angeles
3" tall = PN No. CHR-7110 $18.95
2-1/8" tall = PN No. CHR-7109 $17.95
Old Mar 21, 2001 | 07:07 PM
EROCK's Avatar
Thanks TAZ. as soon as I can I will get one of those. I can get the 2 1/8 one because I also have e 3 inch k-n-n. I have a 3 inch cowl hood so I can go pretty high if I choose to do so.
Eric
Old Mar 21, 2001 | 07:14 PM
Tas's Avatar
Tas
ah well they have 5" tall models too. 14x5"
CHR-7136 $22.95
Old Mar 21, 2001 | 07:27 PM
9177's Avatar
well i really don't know how to help you thats just when i noticed my problem, but like taz said mine is in need of a full tune up. you might try going .045-.050 on your spark gap if you give it a tuneup
Old Mar 21, 2001 | 07:36 PM
EROCK's Avatar
I thought the same thing so I already went .45. It still runs pretty crappy. It probably is the air cleaner thing. Without that thermatrack thing or what ever it is called, it is not getting warm air to the TBI. I will try to hook the old one up
Eric
86CamaroDan
Sep 29, 2015 10:08 PM
middian
Sep 5, 2015 01:42 AM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
