Thermostat???
Old Mar 23, 2001 | 05:31 PM
twells's Avatar
Car: 1999 Tahoe LT 4x4
Engine: 5.7 Vortech 350
Transmission: 4L80E
Thermostat???
I read an article that talked about replacing the thermostat in t.b.i cars and the author suggested a 170 degree stat. I went to the local parts store and told them that i needed a 170 degree thermostat and he said that it would make the car run too cold. He recommended a 190 degree. What should I buy for my 92 R.S. 305 t.b.i.
Old Mar 23, 2001 | 06:21 PM
Neo's Avatar
Neo
I have a 160* in my car so I am not sure what he is talking about.
Mike Kenny
1991 Chevrolet Camaro RS 305 TBI
My Website
Administrator at Auto-Clubs.net
My Baby
Old Mar 23, 2001 | 07:17 PM
Tas's Avatar
Tas
It all depends on what part of the country you live in. Ideally, you don't want the temp below 160. I got a 160* now and it has varied from 150 to about 180 depending on the wheather. I had a 180* before and it stayed at 205-215 and went barely over 220 on super hot summer days. I like my 160* much more. 170 would probably be ideal for me to avoid dipping below 160 but I've never seen one.
-Tas
'89 Formula WS-6
[soon to have Hooker 1-5/8" 50 state legal headers installed]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
Old Mar 24, 2001 | 02:03 AM
idrag2's Avatar
Hey check this out!!! When you run a 160 stat. it makes the car stay in warm up mode.....meaning the car dumps more fuel and air to warm the car up.....which goes back to the saying "More fuel and More Air= MORE POWER" if you run a 170 stat it will make the car will run in a closed loop operation "LESS FUEL AIR AND POWER" So don't listen to the dude at the parts store he is probably not into HI PREFORMANCE. I run a 160 in my 89 TA and it runs like a bat out of hell. Run a stant P/N 13006 an you will be happy. If you have any questions E-Mail me a idrag2@yahoo.com
HOPE I HELPED
I DRAG 2
Old Mar 24, 2001 | 05:31 AM
9177's Avatar
And 150 miles and 3 tanks of gas later you might get were you are going. more fuel = flooding low mpgs and not the best performance.
Old Mar 24, 2001 | 08:31 AM
Andys92RS's Avatar
If you can't find a 170 degree stat. try this. Buy a 180 and drill two 1/8 whole through it. I did this on my monte carlo, soon to do on my camaro. Essentailly what you are doing is lowering the temp that the the themostat opens at. well, not really, but the holes make a small bypass past the valve so it will circulate colder. I did not make this up, I read it in a HI-Perf. mag. Can't remember what one though. It does work. Give it a try.
Old Mar 24, 2001 | 08:47 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i run 160 in the summer and in the stop and go traffic here along with the weather, if had the stock thermo in the fan would run abot every 2 min. THen in the winter when it gets cold i go back to a stock thermo so the car heats up properly and i get some heat as well.
91 camaro RS
- 305 TBI
Mods: Performer tbi intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo, accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edolbrock springs, KYB struts and shocks
Soon to come . Posi 323 rear end , aftermarket LCA,s and panhard bar , Ascd ram air hood, Z28 spoiler and grille , white guage faces.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
