HPs wheel or engine?
Old Mar 24, 2001 | 09:52 AM
nsb35's Avatar
Hi
I have -89 305 (L03) Formula with 170Hp stated. Are those horsepowers given as wheel or engine power?
Thank You
Ben
Old Mar 24, 2001 | 10:46 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
That is an engine calculation. If you want to find out what you have at the wheels just take 20% of 170. That accounts for the inefficiency of drivetrain loss.
1990 RS 305 TBI T-5
.5" turbocity spacer
Summit 14X3 OpenElement W/k&N
Custom Exhaust
MSD - Wires, Cap, Rotor, Coil
Bosch Platinum +4 plugs
Metallic Red w/26,000 miles
Old Mar 24, 2001 | 10:47 AM
Zac's92's Avatar
That's 170 at the crank your probably getting around 150 to the ground if your car is running well.
Zac
Old Mar 24, 2001 | 10:58 AM
nsb35's Avatar
Thank Yoy guys for the info....
Planning to replace the chip and promised to gain some 20 Hp on ground - hope it'll be worth for the $$$.
Regards
Ben
Old Mar 24, 2001 | 11:17 AM
Zac's92's Avatar
On a stock car a chip won't give you 20hp. Use the money you would spend on that and buy an open element with a k&n and a tb spacer or some pullies from march. You don't need a chip until you car has quite a few mods.
Zac
Old Mar 24, 2001 | 11:18 AM
EVILFACE's Avatar
What chip is that? That's a good sized RWH gain for just a chip.
EVILFACE
88 Camaro
Stock 305 TBI Auto,Flowmaster, Full 3" Exhaust, B&M Megashifter
Runs A Blistering 16.5 @ 81.5 mph
http://www.evilface.com/evilscamaro.htm
Old Mar 24, 2001 | 11:54 AM
nsb35's Avatar
Hi
Can't remember the chip maker... all the info is in my office... but Ed is the man and address: ewright@gorilla.net )
They make custom chips.
Ben
Old Mar 24, 2001 | 12:11 PM
EVILFACE's Avatar
Would that be Ed Wright from Tulsa, Oklahoma? If so, I've heard he does a good job on the 4th Gen Camaro's and Firebird's.
EVILFACE
88 Camaro
Old Mar 24, 2001 | 12:52 PM
nsb35's Avatar
Yes, he is Ed Wright and he was recommended to do the job
Ben
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
