need help quick
Old Apr 3, 2001 | 11:35 PM
kjatsi's Avatar
need help quick
I was installing my stereo and when drilling a hole i ground out the solid bkue wire that goes to the ecm I've tried a new ecm and it still does the same thing just crack and no start I have spark form the coil but I do not see fuel coming out of injectors.
Old Apr 4, 2001 | 12:02 AM
Brent's Avatar
I trust you checked the fuses?
Old Apr 4, 2001 | 12:05 AM
kjatsi's Avatar
yes the omly fuse to do with the fuel pump that I can find is the 20amp on the fuse panel. If you know of any others i'd like to know
Old Apr 4, 2001 | 10:27 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
the one under the hood? or is that a relay. you know what im not positive. You DID repair that wire right? thats where i would start, then get a haines manual. or chiltons or something and read the diagrams. find out which wire it was and everthing else on that circuit. start at the begining. wire, and go from there.
Old Apr 4, 2001 | 10:47 AM
kjatsi's Avatar
I can't believe how easy way it is to get to the under hood fuse so it's now fixed.....
Thanks..
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
