crossfire to tbi conversion...
Old Mar 18, 2001 | 10:58 PM
smoove2022's Avatar
i am about to fire up my 1982 transam wich used to have crossfire injection. I have just installed a holley tbi intake manifold an a holley 670 2-barrel tbi. the wiring harnesses for both of these systems (xfire and tbi) look almost identical except the xfire harness has two idle air control connections. should this system work alright or should i put a real tbi wire harness and computer in?
Old Mar 19, 2001 | 12:23 AM
Z28Maniac's Avatar
Fire it up and then you tell us!
Old Mar 22, 2001 | 11:05 PM
82 cross fire's Avatar
It should work just fine if the pins are the same all thay did on th IAC's was split the harness. Good luck By the way do you by chance still have the spark controler from the cross fire system I need on badly. Thanks Dave
Old Mar 23, 2001 | 08:48 PM
jase's Avatar
I used to own an 83 Trans.Computer was my problem.What was wrong with your cease fire?
Old Apr 2, 2001 | 06:49 AM
Twin_Turbo's Avatar
The CFI IAC controllers are just wired parallel, leaving one off won't matter.
Marck
Old Apr 4, 2001 | 04:52 PM
smoove2022's Avatar
Well the engine runs...
It seems to be running incredibly rich however. I thinks the plugs are fouled. I have set the timming and have everything hooked up properly (I think). I havent worked on it in a while but im thinking maybe The tps needs to be adjusted or the fuel pressure regulator (Holley tbi) on the tbi needs to be turned down... I dont know. Any Ideas?
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
NZKnight
Oct 15, 2015 02:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
