Factory chips
Old Apr 6, 2001 | 01:27 AM
nicksL98's Avatar
Factory chips
Hey guys.. I have an 89 Formula that HAD a 305 TBI. It went south and i put in a stock 92 Chevy truck 350. I swapped on the 350 knock sensor and the Whole tb/injectors...BUT what about the chip?
Will the factory truck chip snap right into my Formula's computer and work just fine ..or what? Are they compatible at all? How about the Caprice "police" chip? Part numbers would be helpful too!!
Old Apr 6, 2001 | 08:14 AM
Spyder's Avatar
Hummm, I have no clue at all, I might suggest talking with the PROM people, they know everything
--Spyder--
1992 Camaro RS
LO3, T-56,centerforce clutch, ported and polished heads, Edelbrock Performer Intake, 14X3 Open Element w/ K&N, hiflow cats with two pipes going back, AC delete, SMOG delete, alu drive shaft, 3.73 posi, 170 stat w/ fan switch, STB, Subframe connectors, KYB AGX, Eagle GSC, and poly bushings.
1982 Z-28
327ci CSB, Turbo 350
Old Apr 6, 2001 | 09:51 AM
Brent's Avatar
These are your options as I see them.
Call a dealer and get a EPROM from a 89-90 Caprice. These were the only years when the Caprice used the same ECM (1228746) as your Formula.
The other option is to swap the truck ECM (1227747) and EPROM in place of your current ECM. It will plug right in and run.
[This message has been edited by Brent (edited April 06, 2001).]
gta892000
Aug 11, 2019 11:16 AM
BLK87Z
Sep 18, 2015 11:29 PM
Deemax
Sep 12, 2015 06:53 PM
Ranbo108
Sep 9, 2015 12:20 PM
