Will '88 T/A TBI exhaust manifolds fit aluminum Corvette L98 heads?
Old Apr 5, 2001 | 11:22 PM
MatthewH's Avatar
Will these fit or will the fact that the plugs are angled interfere with the manifolds?
Thanks,
Matthew C. Hall
Old Apr 5, 2001 | 11:25 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
dont be that guy.....get a set of headers before I warp through the monitor and ring your neck. If youre doing heads its a no-brainer to get headers too!
Old Apr 6, 2001 | 12:30 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I don't see why they wouldn't.
I'm going to agree with vortecfcar. Don't do yourself the injustice of going through all the hassle of a head swap without doing the headers too. Installing headers is not an easy task, but, if you've already got the heads off swapping in the headers adds a trivial amount work to your project.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Apr 6, 2001 | 08:53 PM
MatthewH's Avatar
I would get headers but this TBI engine is going into a Volvo 740 sedan (Sleeper The Camaro manifolds will fit the engine compartment provided you mill the surface that mates to the block a degree or two to gain clearance. I was looking at the Edelbrock TES headers but I'm just not sure they will fit. Maybe once the engine goes in I will have a better idea.
Thanks,
Matthew C. Hall
Old Apr 9, 2001 | 08:48 AM
Rock90rs's Avatar
Car: 92 RS/90' vette
Engine: Heads/cam/miniram/blah blah blah..
Transmission: T5/700!
Axle/Gears: 3.08
I can see where you may have a problem getting the plugs in. They are angle plug heads. The vette comes with tubular manifolds, (shorty's) that might be why.
305 TBI
700-R4
L98 cam, 1 5/8 headers, 2 1/2 y-pipe, 4bbl edelbrock performer, holley adapter, open element K&N, afpr, flowmaster catback, MSD coil, accel wires cap & rotor, vette servos, shift kit, 2000 stall converter, TC lockup switch, 3:42rear, all the free mods and some I left out.
Old Apr 19, 2001 | 01:43 PM
95Z28A4's Avatar
I used LT1 exhaust manifolds on my Vette headed ZZ4 in my 1992 S10. The 1994 and 1995 single cat manifolds are the preferred manifolds and are designed for D-port heads. While these manifolds don't flow as well as headers, they do outflow the TBI or TPI manifolds. The dual cat manifolds can be used, but the driver's side head pipe flange may need to be cut down for frame/body clearance and re-drilled and tapped for stud relocation. (Ask me how I know this!). This flange on the dual cat cars are HUGE for bolting a cat directly to the manifold. Also, custom flanges will have to be fabricated to attach the dual cat manifolds to the head pipes. It is much easier to use the 94-95 single cat manifolds. You can probably pick-up a used set of single cat manifolds in the for sale section of www.camaroz28.com for about $30. (I'm a member - notice my username) You will have to drill one additional hole in the exhaust port side of each manifold and use an allen head bolt to attach it to the head at the #2 & #7 cylinders. The LT1 heads have an extra hole on BOTH ends of the exhaust flange for a total of 8 per head. The L98 vette heads have 7 bolt holes.
Mike
Old Apr 19, 2001 | 03:34 PM
Tas's Avatar
Tas
the best stock manifolds are supposed to be the Vette LT4 ones and the big chevy/GMC B van ones.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
transaero
Aug 31, 2015 01:14 AM
timonator
Aug 11, 2015 09:56 PM
