Want to gut harness,What do I do?
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
hey guys,
I'm posting this in the TBI forum to see if anybody here has done this.What I want to do is gut my harness to clean up things abit.my plan is to trim it down and run whats left INSIDE the firewall and out the small hole behind the passenger side head.I know snflupigus had a pic somewhere of a gutted TBI harness but I can't seem to find it.I figure all I need to run from the hole is the wires for the grounds,sensors and injectors.I want to put the Relays on the Driver side firewall by the brake booter on the inside of the car.I can run the wires for the ECM ground,headlights,power steering and the horn behind their respective fenders.what would be a good way of doing this? I basically want to rid the firewall of any wires.The cleaner the better.Any help would be great.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The first step would be to get wiring diagrams. The actual F-body electrical manuals are extremly hard to come by, but chiltons has a complete reprint of the wiring diagrams in its repair manual. Become very familiar with it before you dig into the harness. Wiring is definatly something thats real easy to screw up.
As for passing it through a hole, that will require you to disassemble/de-pin the ECMs main connectors and potentially other items so you can pass the actual wires and pins through the firewall. It may be easier to leave it in its current place behind the fender.
KO1
16
Oct 15, 2015 05:00 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
efiguy
Sep 27, 2015 01:30 PM
