TBI Problem
Old Feb 15, 2007 | 08:06 AM
Fast89T/A's Avatar
Car: 1986 Chevy camaro Z28
Engine: 305 tpi
Transmission: TH-700R4
Axle/Gears: 2.73 posi
TBI Problem
Hi, i am having a little trouble with my TBI T/A. I was going to lunch the other day and it started to fell like it was missing out. After it did that it bogged down really bad and acted like it was going to die going down the road. I got mad and floored it and it still bogged down it didn't kick down or anything and then it finally kicked down and took off like no other. Could thid be something to do with the igntion or the fuel system. Please let me know. Thanks.
Fast89T/A
Old Feb 15, 2007 | 11:37 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Could be a lot of things. Weak fuel pump or ignition, clogged fuel filter, tranmission cable needs adjusted, etc. SES light? Only this one time or always now?
Old Feb 18, 2007 | 02:31 PM
Dougs91's Avatar
Car: 91 Camaro
Axle/Gears: 3.23 limited slip from 91 Z28
Check to make sure you have power going to both fuel injectors. I had this problem before. It ended up one injector didn't get power due to a loose wire coming from the computer.
92camaroJoe
Jul 29, 2023 07:57 PM
db057
Sep 4, 2015 07:57 AM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
