Fuel Gage
Old Mar 24, 2001 | 07:53 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Fuel Gage
My fuel gauge stays way past full then after a little over 115 miles it goes between a 1/4 and 1/2. I know I run out at between 1/4 and 1/2. I have replaced the gas tank, sender, fuel pump, and fuel filter(for something else). This still hasn't solved my problem. I have heard that if you put carb cleaner in the tank it can clean orut your sender and give you a accurate fuel gauge. Any help/suggestions would be appreciated.
Old May 4, 2001 | 01:44 PM
BlackZee's Avatar
My car does the exact same thing-must be a problem with 3rd gen cars!
Old May 4, 2001 | 05:56 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
mine does that too, but why do you consider it a problem. sh#t, i wouldnt spend 1$ to try and fix something as petty as that.
Old Oct 4, 2003 | 08:27 PM
dennis6's Avatar
Car: 1991 Camaro RS
Mine does this and I am about to go fuel cell if I can't find a way to fix it. I was looking for a 84-87 Carb pick up and sending unit as I want my pump out of the tank. The don't make them anymore.
I know a 15 gallon tank that should fit in the hatchwell, but I don't want to butcher the car by sealing the hatchwell off and running lines through the hatchwell.
Old Oct 4, 2003 | 08:48 PM
dennis6's Avatar
Car: 1991 Camaro RS
This the Fuel Cell I was talking about...
Specs:
Vendor: Racer's Choice, Inc.
Product Line: RCI Street Rod Fuel Cells
Material: Aluminum
Finish: Natural
Length: 30 in.
Width: 9 in.
Height: 12 in.
The fuel storage solution for your street rod.
30 in. x 9 in. x 12 in., 15 gallon capacity, aluminum, street rod style, with sender, fuel cell
RCI designed this lightweight aluminum fuel cell just for you street rodders. It features a raised, straight filler neck, a built-in GM 0-90 ohm fuel sender, and a narrow design for frame rail mounting. It holds 15 gallons of fuel and measures 30 in. x 9 in. x 12 in.
Old Oct 4, 2003 | 08:52 PM
dennis6's Avatar
Car: 1991 Camaro RS
Anyone know if this will severly hurt handeling or acceleration? I see alot of stock vehicles with the fuel tanks after the rear end.
Old Oct 5, 2003 | 07:19 AM
vwdave's Avatar
My gauge was stuck straight up all the time.
Was the gauge. Changed the cluster ($50) and fixed it.
Old Nov 13, 2003 | 09:27 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
Mine does that exact same thing...but I don't think it is the gauge. Can anyone give me a site that has the entire sending unit assembly for a TBI that isn't an arm and a leg. Chevy is wanting over $500 for the entire thing...and I NEED to get my fuel pump replaced and would like to get the gauge to read. I like doing math and everything but having to calculate how many miles I have driven and how many more I can go on one tank gets kinda old. thanks all
Old Nov 13, 2003 | 10:19 PM
Nate's 88's Avatar
don't know where you can get one for cheaper, but i know i'd be damn sure it wasnt my gauge before i went out and spent 500 bucks with the conclusion of "i don't think it's the gauge". just give/take ground to your gauge, if the needle moves without any problem then it's not your fuel gauge.
Old Nov 14, 2003 | 11:55 AM
JR92z28's Avatar
Car: 1994 Z28
Engine: 5.7 LT1
Mine used to go/be empty at the 1/4 mark.
After I put in a new Fuel pump and filter, the gage reads empty at the 1/2 tank line.
If I fill it up, the gage moves past the Full tank line.
Strange....
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
BewleyBizzIROC
Sep 7, 2015 08:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Irocohio
Aug 12, 2015 08:03 AM
