Headgasket... Decisions, Decisions...
Old Feb 18, 2007 | 05:51 PM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey everyone,
I just got finished putting a new trans into my car & I noticed coolant dripping out of the engine. Looks to be near the headgasket. Heres the deal its a mostly stock 305TBI w/ 165k miles on it. What should I do? I know I can get a 90k mile LO3 for cheap to swap in or I can just replace the gaskets on my engine. If I replace the gaskets, what else should I do while im in there? I dont want to get too crazy because I probably wont have this engine too much longer (LT1 swap planned next winter)
Thanks,
Mark B
Old Feb 18, 2007 | 08:24 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
pull the heads off, have them magnufluxed, vacuum tested, if that checks out good have them resurfaced. new head gasket set. and be done with it. no sense in doing anymore that that.
Old Feb 18, 2007 | 08:42 PM
JerseyMark's Avatar
Engine: 96 LT1
Thats kind of what I was thinking too. Usually when something breaks, I build it better. But in this circumstance, I will probably just fix it. (Mabey a pocket port job? haha)
Old Feb 18, 2007 | 11:26 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Could also be from the intake manifold. Lot more likely as the head gaskets blow out internally since the escaping combusion gasses vaporizing the gasket are what cause the leaks.
Old Feb 19, 2007 | 07:30 AM
JerseyMark's Avatar
Engine: 96 LT1
Good point. I will have to investigate it further.
ZZ3Astro
Aug 13, 2019 12:57 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
3.8TransAM
Sep 3, 2015 06:38 PM
BlackTopKing
Aug 19, 2015 12:13 PM
