Anyone had any luck porting there TBI units?
Old May 17, 2001 | 12:57 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
A couple of years ago I screwed up my fuel injector pod so I had one sent to me from a junk yard, but I had to buy the whole TBI unit. Not too bad for only 60 bucks including the injectors. But anyway, all that I need was the pod so that's all that I used, so I still have to Throttle body and its collecting dust. But anyway, I was wondering if anyone knows whats steps I should take to port it. Do I need new oversized butterflies and if so, where can I get them from? Also, I can't remember from the last time I had it off, but are the ports on the top of the stock intake bigger or the same size as the throttle body bores, cause I don't wanna waste my time trying to get more air into the throttle body if I can't get it into the intake. Any suggestions and comments please?
91 Forest Green Firebird with TBI 305 3" Edelbrock Cat back, Dynomax headers, matched flow fuel injectors, injetor spacer, throttle body spacer, MSD Blaster coil, 8.5 mm MSD wires, 160 degree stat, Hypertech Thermomaster chip and low temp fan swich
Old May 17, 2001 | 04:15 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
check out the artical the the tech section sabout " the ultimite tbi mods" that will help ya
Old May 17, 2001 | 08:04 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
you can port em to 48mm, NO LARGER sorry. youll need larger butterflies, and the holes on the stock intake are the same size as the stock tbi (1 11/16")
Old May 22, 2001 | 07:58 AM
91Firecrow305TBI's Avatar
I just did the same thing to my TBI. There is a tech article on this, under technical articles on the main page. Look for Ultimate TBI II... should be helpful
Flowmaster 80 series muffler
K&N Open Element cleaner
Ultimate TBI Mods Subframe Connectors
lead pedal foot . See my baby @
http://oursportscars.homestead.com/home.html
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
92camaroJoe
Aug 13, 2015 06:07 AM
