quick power adders
Old May 26, 2001 | 02:14 PM
91rscruiser's Avatar
quick power adders
ok im goin racing tomorrow for the first time with my stock 91 camaro rs,305 of course,and i was wondering if theres anything i can do at the track between rounds that would help my car go even a little bit faster.any help would be appreciated.
-1991 camaro rs,dark red metallic,t-tops,stock 15inch rims
-stock L03 305,th700r4,only mod for now is a flowmaster 80 series replacement muffler.
Old May 26, 2001 | 03:38 PM
Andy89RS's Avatar
Bring a timing light and play around with the timing a little. At the track really is the best place to check the results of different timing settings. Between rounds open your hood to help the engine cool faster, and run it as little as possible until you are about to pull up to the line.
Old May 26, 2001 | 04:28 PM
JPrevost's Avatar
Car: 91 Red Sled
N2o is an option to get into the 13's.
There are lots of tricks like disconnecting front sway bar endlinks. Search the forum, there is plenty of info on the site.
, Jon (350 TBI!)
91 Red My website
Old May 26, 2001 | 05:50 PM
test sig
Old May 26, 2001 | 05:52 PM
test again
Old May 27, 2001 | 01:03 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I found that to cool the engine fast, I turn on the A/C with the engine off, but the key on while your in the pit area. This turns on the cooling fan way cooler. Cooler than the Hypertech Fan Switch I just bought. And yea, put the hood up too.
Also, if I pull the plug from the back of the A/C compressor (and wrap it w/tape so it don't ground out), then the fan will stay on while I am pulling up to the staging lanes, but the compressor won't kick on. That helps keep the engine cool while it's running, but again doesn't turn on the A/C. Just a little trick I figured out somehow.
I guess I ain't as dumb as I look.
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
Old May 27, 2001 | 01:38 AM
JPrevost's Avatar
Car: 91 Red Sled
I just have it so my fan is on when the car is on .
, Jon (350 TBI!)
91 Red My website
1986Z28OWNER
Dec 13, 2015 10:19 PM
mike_c
Aug 27, 2015 04:32 PM
sailtexas186548
Aug 24, 2015 10:11 PM
happyhapka
Aug 15, 2015 04:42 PM
L98GTA87
Aug 5, 2015 11:02 PM
