Fuel Lines
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Fuel Lines
OK getting the HOT 305 ready to go and having one problem.....The fuel lines will not line up because the manifold is higher and the spacer raises it even more. The question can I splice a rubber fuel ine in the middle like a Carb would use to get a little more play in the lines....
THanks
Brian Felts
THanks
Brian Felts
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I have heard of people doing that. I think they got a special fuel hose for high pressure pumps. That's what is between the tank and the hard fuel lines. Isn't it?
I ain't 100% on that. GL
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
air cleaner
-B&M TransPak
-Jet Stage2 Chip
Car: 91 Red Sled
I just bend mine and I went from stock to the edelbrock RPM, 1" adaptor, holley unit. The only hard part was getting the fuel lines on the TB. I found it much easier to install the fuel lines while the TB is just floating above the intake. THEN I just pushed the thing into place and had a friend tighted it down. My problem wasn't the length of the lines but the little vacuum piece (ported) was hitting the line and I couldn't figure a way around it.
, Jon (350 TBI!)
91 Red My website
, Jon (350 TBI!)
91 Red My website
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
leaking fuel is bad. obviously. if i were you dont try to save money by riggin something up. bending is ok, cutting and splicing is bad. just buy the correct fittings and convert the metal lines to high pressure reinforced rubber lines. with the correct fuel line clamps as well.
Yes, you can splice in rubber fuel lines, and it probably won't leak, ever, 12 psi is nothing.
BUT you run the risk of burning you car to the ground if they ever do leak, it's not worth it.
I really like JPrevost's idea of bolting them up and then bolting the TBI down.
When I installed my 3/4" spacer I think I just grabbed the lines and bent them by hand until they fit.
Thanks guys I think you all have helped me greatly. I Hope to get it running tomorrow.
Brian
1989 Camaro RS
305 .030 over
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter LETS PLAY FORD!!
Brian
1989 Camaro RS
305 .030 over
theshackle
Mar 5, 2017 06:37 PM
ambainb
Apr 25, 2016 09:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
