crossfire tbi converted to carbs
Old Feb 27, 2007 | 01:56 PM
Waldo's Avatar
We have a 82 IROC with non funtioning tbi, I'm old school and would like to convert to carbs.
Does a regular small block manifold work? What is involved
Old Feb 27, 2007 | 05:41 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Welcome to TGO.First does your '82 actually have IROC decals on it?The reason I ask is the IROC package(RPO-B4Z)wasn't available until '85.The motor you have,VIN eighth digit "7" for '82,is a LU5 305 with Crossfire Injection.Does she run at all,runs rough,check engine light on?
The answer to your question on converting to a carb setup.You have a couple ways to go.You'll need a 4bbl intake,Edelbrock Performer is a good choice,and you can either run a computor controlled quadrajet with the distributor you have now.The ECM chip will have to be changed to one for a LG4.Or the simpler route you can swap out using a non-computor controlled carb and a distributor with vacuum/mechanical advance.Going this route you can discard the computor since it won't be controlling anything.But I advise against cutting up the harness just remove it with the rest of the components if you go this route.
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
tero
Aug 15, 2015 02:47 PM
tero
Aug 6, 2015 06:34 PM
3rdgenparts
Aug 6, 2015 09:03 AM
