lt1 heads and cam on 305 tbi
Old May 31, 2001 | 10:05 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i have seen some stock lt1 heads for sale that look fairly good and was wondering if it was possible to put these on my 91 305 tbi with and lt1 cam.i know theb cam will work b/c i have seen that but would i have any problems with my edelbrock tbi intake?? would it be fairly simple. right now im just kind of investigating this so any advise you guys have i could use.
thanks
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets, 323 gear
Old May 31, 2001 | 11:34 AM
Tas's Avatar
Tas
it is possible but not really worth it. I have an article on my site. New water passages have to be drilled and sleeved. Old water passages have to be caped and welded. Intake bolts all have to change because GenI intakes don't bolt onto the GenII heads. They would have to be milled slightly I think to keep the compression up.....
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old May 31, 2001 | 01:25 PM
bbtaz97's Avatar
Car: 91 RS
wow .. your right its not really worth it.. after reading the article..
thanks
Old May 31, 2001 | 01:51 PM
EVILFACE's Avatar
The cam would be worth it, but as Tas said the heads wouldn't.
EVILFACE
88 Camaro
Stock 305 TBI Auto, Flowmaster, Full 3" Exhaust, B&M Megashifter, K&N Open Element
Runs A Blistering 16.5 @ 81.5 mph (due to major tire spin)
http://www.evilface.com/evilscamaro.htm
Old May 31, 2001 | 03:06 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
You wouldn't have to get 'em milled anyway. LT1's have a 55cc combustion chamber...As good as the LT1/LT4 heads are, they are certainly not worth the trouble to retrofit 'em onto earlier blocks.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old May 31, 2001 | 03:10 PM
bbtaz97's Avatar
Car: 91 RS
THANKS FOR THE INFO GUYS.. I AM GONNA DO THE LT1 CAM THROUGH...ASSUMMING THE CAM IS IN.. WHAT WOULD BE THE NEXT STEP IN TUNING IT??
91 camaro RS
- 305 TBI
Old May 31, 2001 | 06:23 PM
Tas's Avatar
Tas
you would have to still mill them because you need to mill off the leftovers from the water coolant plug that is welded on to the face of the head.
xkingcodex
Feb 12, 2020 07:43 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
pimp2303
Jul 27, 2017 02:03 PM
