14" Drop Base rests on the coil...
Old Jun 13, 2001 | 03:17 PM
GndPrx's Avatar
Ok, just picked up a 14" drop base and the damn thing sits right on top of the coil and doesn't seat 100% on the TBI. Also sits right on top of the throttle cable, but this doesn't worry me as much as the coil.
What did everyone else do different? I don't like metal sitting that close to the ignition.
Thanks,
Carl
CarAudio Resources
Old Jun 13, 2001 | 03:33 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Mine fit nicely and did not interfere with any cables. It does rest on top of the distributor, but as long as the wire insulation is good there will not be any problem. Did you keep the spacer ring on your TBI unit? If you have the clearance, install a TBI spacer.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Jun 13, 2001 | 04:11 PM
92Camaro305TBI's Avatar
Pukka, Where did you get the MacEwen white-face guages? And were they hard to install?
92 Camaro 305 TBI Automatic. Everything stock so far except a shift kit.
Future mods. Spark plug wires and plugs, tint, new 3inch pipes. Maybe putting 2 glass paks for effect. any other advise on getting to 300+ HP would be appreciated. Thanks
[This message has been edited by 92Camaro305TBI (edited June 13, 2001).]
Old Jun 13, 2001 | 05:04 PM
JPrevost's Avatar
Car: 91 Red Sled
http://www.macewen.net/
BTW: I hope you're still using the stock spacer ring. If you don't then the drop base will sit on everything. Look at the stock air cleaner and the spacer ring should be stuck to the bottom (like most). If you are using the spacer ring then you have something abnormal with your air cleaner (doubtful) or you don't have a chevy small block (also doubtful).
, Jon (350 TBI!)
91 Red My website
Old Jun 13, 2001 | 05:36 PM
GndPrx's Avatar
Nope, factory spacer is still there and it still sits on top of the coil. Dunno.
It's an ACDelco drop base 14". Guess I'll have to try to build something to prop it up a little higher and still seal.
[This message has been edited by GndPrx (edited June 13, 2001).]
Old Jun 13, 2001 | 05:52 PM
firbird's Avatar
Is this what you are talking about?
http://firbirdgta.tripod.com/cars/id8.html
Yea I tried to fix it by putting liquid electrical tape on it, it did not work as well as I wished it would I still need to fix it and I probably just put a piece of cardboard over it for temporary because I hear it can do some damage if it goes through the wire into the base of the air cleaner.
Old Jun 13, 2001 | 06:03 PM
GndPrx's Avatar
Ok, I guess that little 1/8" of gasket or whatever from the original was all I needed to get clearance of everything.
Thanks for the help all. Now I just need to get a breather for the valve cover and I'm all set. The car is much more responsive now and idles quite a bit better than it did before.
Carl
CarAudio Resources
Old Jun 13, 2001 | 06:48 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
did you read the tech article i wrote?
BEND the bracket that the coil is mounted to the intake with. it will bend backwards and downwards about half an inch and not interfere with anything.
as for the throttle cable. try a homemade carb aircleaner spacer ring made out of flat cardboard. go for it.
Old Jun 13, 2001 | 07:16 PM
dtpmike's Avatar
all you have to do is snip a little chunk out of the bottom of the element, then wrap the wire in electrical tape jsut in case.
Old Jun 13, 2001 | 07:36 PM
Pukka's Avatar
I got the gauges installed in about 30 minutes...instructions were very accurate and easy to understand
Old Jun 13, 2001 | 07:38 PM
Pukka's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 92Camaro305TBI:
</font>
So thats how you do that!
Just figuring out how to quote someone.
BOOT77
Oct 17, 2015 12:09 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
corey8084
Sep 17, 2015 02:56 PM
Formula_88AE
Sep 3, 2015 01:47 PM
