Now, for heads with the LT1 cam...
Old Jun 14, 2001 | 01:52 PM
BahamutRS's Avatar
Found an LT1 cam for my L03. Now, aside from the other things I a, getting for the cam, I was considering heads. Now, should I have something done to the stock ones or invest in new ones? Keep in mind I'm not Mr. moneybags and I just spent a billion dollars on Edelbrock TES headers, SLP cold air, Flowmaster, NOS, etc...so has anyone had experience with aftermarket heads THAT WERE CHEAP? What do you think of them? And..uhh...how much were they?
Old Jun 14, 2001 | 03:07 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
Here are a few options...
1)Vortec head kit $679.95 + machine work (.040" off the bottom)
This would be everything that you need to run the Vortec heads. kit includes assembled Vortec heads #12558060, head gaskets, head bolts, rocker arms, Edelbrock Performer intake, intake gaskets and 12 point stainless steel intake bolts.
2)Aluminum L98 heads $799.00 + intake
With this option you would still need to get a new intake manifold and an adaptor plate. You would not, however, need to get the heads machined.
There are a few other options out there, but I'll leave those for someone else...
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Jun 14, 2001 | 07:29 PM
JPrevost's Avatar
Car: 91 Red Sled
The vortec kit is worth every penny. Best darn cast iron GM heads ever made if that says something!
I understand the "not made of money" part but you get what you pay for and the vortec heads leave NOTHING to be desired. Better flow for the street (under 3000rpm on a 350ci) than the vette heads!!!
The best part about that deal is that it comes with the intake and all the hardware.
, Jon (350 TBI!)
91 Red My website
Old Jun 15, 2001 | 07:52 PM
92fire-audio's Avatar
Will vortech heads work with edelbrock tes headers? Just curious because I plan on getting them both at the same time and don't want a headache..
Old Jun 16, 2001 | 12:06 AM
Blown 305 TBI's Avatar
OK, I have 2 questions about the vortec kit.
1. The heads are designed for a 350, which is why we would need to mill them down .040" to keep our compression ratio the same as stock, I understand this. BUT, doesn't the 350 have a larger cylinder bore than our 305?? If this is true, which I think it is, won't there be the potential of the valves hitting something?
2. Is that intake manifold able to accept an EGR?? I need to keep my car emmissions compliant, so if it can't accept and EGR then I can't do it.
Mike
Car:
92 Formula
Stock 305 TBI and 700R4 trans
Mods:
7psi Paxton
Edelbrock Coated headers, high flow cat, Flowmaster catback
SLP takeoff posi, GM 3.42's
Nitto Drag Radials (245/50/16) on ARE road racing rims (18lbs lighter each)
Best 1/4 mile - 14.421 @95.96 w/a 1.983 60'
Old Jun 16, 2001 | 06:31 AM
Mark305TBI's Avatar
Vortec heads have 1.94"/1.50" valves, they do clear the cylinder bores. You don't run into cylinder wall clearance issues until you get bigger than that with more than .450" lift (read that on Edelbrock's Website).
<font face="Verdana, Arial" size="2">S/B Chevy heads may not be used on engines with less than 4" bore (262, 265, 283, 305, 307 c.i.d.) except with cams having less than .450" valve lift.</font>
I'm not sure if 2.00"/1.60" valves will clear or not, but 2.02"/1.60"s won't.
Not sure about the EGR. I don't think that Vortec heads have EGR provisions, but, I'm not certain.
-Mark W.
[This message has been edited by Mark305TBI (edited June 16, 2001).]
Old Jun 16, 2001 | 06:36 AM
Mark305TBI's Avatar
I just realized that the quote above is misleading. It's from Edelbrock's website and it's refering to their cylinder heads because of the valve size.
-Mark W.
Old Jun 16, 2001 | 06:50 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
What about the S/R torquer heads specifically designed for the 305?
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
Redwhisper
Aug 26, 2015 05:02 PM
