Ram Air
Old Jun 16, 2001 | 09:29 PM
91 RS AGAS's Avatar
Ram Air
Cut snorkel off leaving 3inches.Cut hole in front of air cleaner leaving 2 tabs on each end.Take tube that went to snorkel and fasten oval end over tabs in front hole seal to air cleaner.Obtain 3inch air inlet hose at autozone etc.Install hose to cut off snorkel and to tube you just put to front of air cleaner.Remove inside headlights,run hose through 3inch existing holes behind lights fasten to light sockets,make nice scoop,install coarse screen in headlight retainers to keep the big bugs out etc.I then installed 3inch tall KN element added 1inch rubber (door seal)around air cleaner top to seal it up tight.Works better then open element I had and it is cheap!
RICH
Old Jun 17, 2001 | 10:50 AM
dtpmike's Avatar
well yeah its a nice idea assuming its not raining hard or its not dark out and you need your brights.
Old Jun 17, 2001 | 03:07 PM
91 RS AGAS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 91 RS AGAS:
</font>
YOU still have high and low beam on outside headlights. You could also run hoses under bumper, or move parking lights to grill and use those holes for air pick up etc.You just have to use some thought and experiment.If you still arent feeling bright enough add fog lights!
Old Jun 17, 2001 | 04:40 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Honestly, no offense, but how clean does that look? Sure performance is nice, but I rather looks and performance than a ghetto rigged set-up that works better. There's only one homeade setup that I've ever seen that didn't look bad. I guess I'm just picky.
Old Jun 17, 2001 | 07:02 PM
91 RS AGAS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by soulbounder:
Honestly, no offense, but how clean does that look? Sure performance is nice, but I rather looks and performance than a ghetto rigged set-up that works better. There's only one homeade setup that I've ever seen that didn't look bad. I guess I'm just picky. </font>
Looks very clean if done neatly.All portions must be secured with tyes and fit of new snorkel to air cleaner if done properly looks factory if done neatly,last car show I was at the car took first place in 1990 to 2000 class against corvettes monte carlos etc.Many people at the show ask me were I ordered the ram air kit from so I dont think it looks bad.Of course even factory parts can look like s t if the wrong fool gets heavy handed.My RS has 84000 actual miles and has t tops pwr everything ac,in other words just about every option avalible and is garage kept.I tell you this to let you know I am very concerned about apearence also and would not GHETTO it up as you said. Basicaly the car looks like new inside and out. Thanks Rich
Old Jun 17, 2001 | 10:25 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Well I'm glad to hear it looks kick a**. Where's the pics. I wanna see. Congrats on the 1st place wins!
Bubbajones_ya
Jul 6, 2024 08:32 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Stangski09
Nov 14, 2015 01:27 PM
edoff13
Sep 11, 2015 03:55 AM
09ave
Sep 7, 2015 06:03 PM
