Timing Gear
Old Jun 13, 2001 | 12:23 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Timing Gear
What is a good timing gear/chain for a 1992 Camaro LO3 with a LT1 cam?
Old Jun 17, 2001 | 02:13 AM
Vader's Avatar
Brody,
The single roller GMPP timing set is a nice unit. It's heavier and stronger than the double-35 chains found on most aftermarket timing sets. If you don't mind the little extra mass, it's a stout setup. If you want to be able to snap up to 6,500 RPM in an instant, use a lighter set.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 17, 2001 | 09:45 PM
steve8586iroc's Avatar
You can get the single roller chain set from Scoggy Dickens for 15 bucks http://www.sdpc2000.com/cart.asp?act...d=839&pid=8446 . It's a new take off from a crate engine. I got mine there, can't beat the price.
Steve
[This message has been edited by steve8586iroc (edited June 17, 2001).]
Old Jun 17, 2001 | 11:40 PM
Says it cant be used with a LT1. Can it be used on a LO3 with a LT1 cam? 15 bucks sounds good
eightsixseven
Dec 16, 2024 01:50 PM
junkcltr
Aug 2, 2019 11:12 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
86White_T/A305
Aug 17, 2015 12:16 AM
