crossfire injection
Old Jun 12, 2001 | 01:31 AM
Nosanity's Avatar
crossfire injection
I just recently received an 82 trans am w/ a 305 crossfire injection. If anyone could give me a clue on what I can do with the following questions, I would consider you in my will. =)
* The book calls a 6 for my timing. The engine has no power what so ever and pulsates. When I time it to a 10 however, it runs like a dream. Any suggestions why?
* On occasion, when I accelerate from a dead stop, the TA seems to not get any gas to the engine. "bla.blahblahblah..blahblah". No power at all and it was floored. After 6 - 7 seconds of choking, the TA flies like it never happened.
The tank is full, the injectors have been cleaned via cleaner, new fuel pump installed, etc. I run 92 octane in my engine. Any suggestions to what the problem may be?
Old Jun 12, 2001 | 01:44 AM
Nosanity's Avatar
One other thing, if there are any crossfire owners or anyone that knows alot about them, please give me any sites or anything that would help me learn more about how they operate. Thanks.
Old Jun 12, 2001 | 01:40 PM
RED82TA5.7L's Avatar
Car: 96 Formula/82 T/A
Engine: LT1/350 TPI
Transmission: T56/TH350
well. i dont know much about it. but when i have a problem with mine i go to http://www.crossfire.homeip.net/ BUT. right now the site is down.. i talked to the webmaster and he said its saposed (SP?) to be up in about a week.(they are going from cable to DSL) so try the site in a couple days. and its a very good site. there are people running low 13s there with the CFI system.
RED82TA5.7L
1982 Pontiac Trans Am
Cross-Fire Injected 5.7l V8
New TH350 Raptor with a shift-kit, 2600 stall torque converter, Eldebrock TES Headers, 3" Hooker Cat-Back.
Mods: 1.6 Proform Roller Rockers, electric fan, Corvette 5.7L computer chip, K&Ns, MSD 6A Ignition Box, MSD Conductor Spark Plug Wires .
Audio: JVC Kameleon CD deck, Jenson 4x6 front, Eclipes 6x9 rear, 2 10" mTx T4000 powered by a mTx 200watt amp.
Black Powder Coated 1990 16x8 Formula Wheels with 245/50/ZR16 Perelli P7000, 1.5" Jamex Lowering springs(pics are before lowering springs, ill get new ones soon).
For Pictures go to
http://members.theglobe.com/RED82TA57L/mycar/
A cool Trans Am site with Message Boards http://www.transamgta.com
Old Jun 14, 2001 | 02:06 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
This is a direct link to the CFI message board, which is functioning fine right now. With this link you won't have to go through the page listed above;
http://www.enteract.com/~mikew/cgi-bin/Ultimate.cgi
About your timing, run as much as you can get w/o pinging. That will give you the best power and fuel economy. About your acceleration problem check your fuel presure, MAP sensor, and TPS, and wiring harness connections.
Enjoy!
'83 Trans Am: 400 CID oil burning junkyard long block, 224/234 crane cam, Summit aluminum roller rockers, hand ported intake, home bored 2.09" (53mm) throttle bodies, MSD 454 injectors(75 lb/hr), Holley 255LPH fuel pump, custum modded FPR, Edelbrock TES headers, SLP 3" stainless steel cat back, stock ECM & chip. Borg/Warner T-5 World Class, 12" Corvette rotors and clipers, GTA 16" wheels, South Side Machine subframe connectors, 1LE sway bars, 3.45 ring and pinion, Alpine sound.
Best E.T. 13.532
Best MPH 102.24
Old Jun 14, 2001 | 02:35 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Tom, one of my good friends from that board, Gidvette84, has an 84 vette with the crossfire. It just looks awesome, lol. One day I'd really like to experiment with an offy intake and use two duel TB's. Anyway, how much power is your 400 putting out? And what kind of heads are you running?
Old Jun 19, 2001 | 12:25 PM
Engine: LT1, L400
Soul,
That's cool that you know Gid. I too think the Offy is the ultimate way to go. I haven't yet, because my heads won't support that much flow, therefore at this point that intake would be too big.
As for my set up, my engine is a junkyard long block, late '70s smogger 400 that also happens to be pretty tired. The heads are stock and I noticed when I put the intake on that the valve had some good "califlower" build up on them. Obviously this engine could be much better. In its current form, it is making approximately 300 hp at the flywheel.
Let me make something clear. When I put this engine in, my goal was the get into the mid 13's spending as little money as possible, while still getting over 20 mpg on the highway. Goal achieved. Now I want 12's so I plan on rebuilding the motor this coming winter, w/heads etc. But the bang for the buck cubes can offer is hard to beat.
Best E.T. 13.532
Best MPH 102.24
NZKnight
Oct 15, 2015 02:47 PM
Tweeks25
Sep 17, 2015 08:04 AM
edoff13
Sep 11, 2015 03:55 AM
