idle
Old Mar 9, 2007 | 06:51 AM
ryan77's Avatar
Car: 89 Camaro, 00Xtreme s-10, 89 Buick "Party Ave"
Engine: 305tbi
Transmission: 700r
idle
how do I go about setting the idle on my 89 305tbi, it's idleing around 1200-1300 rpm...also I'm looking for a escm(mines missing) could that be the reason it idles high????
Old Mar 11, 2007 | 02:04 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
There is no way to manualy adjust the idle speed. It is controlled in the chip but can be adjusted if you burn your own chips. It sounds like you have a problem that is resulting in a high idle. Vacuum leaks, improper base timing or a lack of an ESC as you suggest can cause a high idle.
Old Mar 12, 2007 | 08:22 AM
ryan77's Avatar
Engine: 305tbi
Transmission: 700r
just the other day it start idling down...about 800 rpm...after it warmed up a little bit...and I still don't have a escm...and its now running fine....I've driven it 10 miles or so...when/what will I notice that the escm isn't there..and what will happen?....I do plan on getting one from a junk yard soon.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
