Torks size on smog pump?
Old Mar 11, 2007 | 03:41 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Not sure if this is the right place for this, but does anyone know what the size is on the torks bolts on the smog pump on a 89 TBI car????? Thanks, Tom
Old Mar 11, 2007 | 11:16 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
They are T-45 if I recall, they may be T-50. they are one of the two. I would have to go dig thru the garage, and try to find the bolts for the accessory system from when I had serp belts. I'm too lazy for that though. I also want to think that there were two diffrent torx bits used, but that have only been on the alternator side.
Hope that helps. I would say I am 80%-90% that they are T-45 though.
Old Mar 12, 2007 | 07:20 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Went and bought a t-45 it is a bit big, a t-40 seems small but it fits..those bolts are a beast to get off..I bet they did that on pupose.Any suggestions guys, the car is down cuz of those 2 bolts.Thanks, Tom
Old Mar 12, 2007 | 01:44 PM
Dewey316's Avatar
Car: 1990 Camaro RS
if the t-40 seems small, i bet it is a T-45. make sure you clean them out good, then maybe use a small hammer to get the bit in and catching good. The other trick, is to use a pry-bar to push on the end of the ratchet, to push the bit into the bolt, while you loosen it.
Old Mar 12, 2007 | 02:37 PM
ryan77's Avatar
Car: 89 Camaro, 00Xtreme s-10, 89 Buick "Party Ave"
Engine: 305tbi
Transmission: 700r
clean all the grease and gunk from around them w/ a razor blade...then soak em real good with p.b. blaster, or wd-40...then tap on them with a hammer(to vibrate em a little so the penetrating oil and get in there real good....let it soak a day or so....then use a breaker bar and the torq socket and with pressure on it smack with a hammer...they'll come out for sure...
Old Mar 12, 2007 | 07:34 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
I hate those 2 bolts, they have ruined my life, I have tried all the tricks, and have ended up rounding them out........AAAHHHHHHHH!!!!!!!!!!!!!!!This whole job has turned out to be a disaster....Any more ideas guys????? Thanks, Tom
Old Mar 13, 2007 | 04:06 PM
Dewey316's Avatar
Car: 1990 Camaro RS
It depends on how rounded out it is. If you really mangled it up, you might be screwed. There is a point, where I would have to be there to see what options there are. you may be looking at easy-outs, or cutting the head off of it, and getting the brackets off, the getting the rest of the bolt out with vice grips and chanel locks. It all depends on how damaged things are, and what kind of access you have.
I have the must luck with really stuck bolts, by using a braker bar, and while pusing on the bar, I keep pounding the bit into the bolt, the combination of driving the bit into the bolt, and the impact brakes things loose.
Old Mar 13, 2007 | 08:53 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Dewey, that is a good idea...I very seldom do thing like this, I was in a hurry, and did not clean them out like I knew I should have done.....Think i will grind the heads off, then get them out, when they go back in, they will NOT BE TORKS, I HATE THOSE THINGS......................I am looking for a way to get rid of some more of the "Bracket, AC Delete thing" Want to clean the front of the motor up some more..It looks 100 percent better now..Thanks for the replys, Tom
Old Mar 14, 2007 | 12:49 AM
Dewey316's Avatar
Car: 1990 Camaro RS
be careful taking to much out, there is a good amount of tension on those. I sheared a bolt of in the head, by trying to remove too much of the brackets. I finaly just went to a v-belt setup, to clearn things up, since I only run a PS pump, and alternator.
Old Mar 14, 2007 | 06:48 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Thanks, well all I really want to have on the car is PS, and Alternator.....May end up doing that.....Want a more balanced look, and that bracket is freaking ugly.......Tom
Old Mar 14, 2007 | 10:23 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
HEAT! get a cheap propane torch. I have used mine so many times its not funny.. while working bolts loose on my 73 914. talk about stuck bolts, try 35 years old!
Vice grips if you rounded it out.
PB blaster or some sort of penatrating oil (i use some that has some graphite in it). then propane... have fire extinquisher handy, I've never had penatrating oil catch fire on me out of control but always good when playin with fire. Then clamp those grips on their HARD and get a big f'n hamer and see what happens.
Old Mar 15, 2007 | 08:20 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Dewey, do you have a picture of the front of your motor, would like to see the setup you have, as I may doo that..
.Snflupigus, Thanks for the info..........
Old Mar 16, 2007 | 03:46 PM
Dewey316's Avatar
Car: 1990 Camaro RS
I don't seem to have one right now, I'll snap a picture sometime this weekend.
Old Mar 17, 2007 | 07:41 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Alright!!!!!! Thanks alot.........
italiano67
Dec 11, 2016 09:21 AM
toronto formula
Nov 10, 2015 06:17 AM
anesthes
Aug 24, 2015 08:18 PM
1985chevydude
Aug 22, 2015 05:36 AM
knight72
Aug 10, 2015 09:32 PM
