need advice!
Old Jun 26, 2001 | 10:23 PM
twells's Avatar
Car: 1999 Tahoe LT 4x4
Engine: 5.7 Vortech 350
Transmission: 4L80E
need advice!
I have a lo3 right now and am trying to sell it for a 4th gen z-28. if i end up keeping my car, i want to put a 383 or a 406 in it. I want to do this and spend as little money as possible. my engine requirements are around 450 h.p. and 450+ lb/ft torque. should i switch over to carb. or should i modify the throttle body? I want this to be cheap but effective. If i keep my t.b.i. what combination of tb, intake, chip will be able to support a 450+ motor? thanks!!
Twells
1992 R.S. 25th Anniversary
* Borla
* Open Element
* Hypertech Chip
* Smog pump delete
Thats all for now!!
Old Jun 27, 2001 | 12:27 AM
Tas's Avatar
Tas
keep it TBI as long as possible and if that's the restriction, swap it out. 450TQ TBIs have been documented. It was a 383 but was lower on the HP. think it had 300HP.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Jun 27, 2001 | 12:39 AM
twells's Avatar
Transmission: 4L80E
thanks, anyone else. i would also like to still have some horsepower. i could settle with a 383 but would still want the same power requirements. is this possible or am i dreaming. would a carb be cheaper than all of the tbi upgrades (spacers, high flow tbi, matched injectors) what about the turbo city high volume tbi fuel pump, will i need that? Thanks
Twells
* Borla
* Open Element
* Hypertech Chip
* Smog pump delete
Thats all for now!!
Old Jun 27, 2001 | 11:18 AM
twells's Avatar
Transmission: 4L80E
If i did all of the free tbi mods and the turbo city upgrades (minus the high flow tbi) and put a stout 383 underneath it would that modified tbi system support it ok w/o engine codes or performance problems.
Twells
* Borla
* Open Element
* Hypertech Chip
* Smog pump delete
Thats all for now!!
Old Jun 27, 2001 | 12:05 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Your stock TBI will not flow enough for a 383 even with the ULT TBI mods. The Holley 670 Cfm however and a custom chip can make it run in my opinion, for now the TBI mods will make a big diffenece with a complete exhaust.
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Jun 27, 2001 | 01:17 PM
NTChrist's Avatar
Carb would be way cheaper in the short-term. You might see enough of a return of your investment on EFI in the fuel economy to justify it, though. I haven't tried it myself, but a 450+hp TBI setup sounds like a pain in the butt.
No guts, no glory.
Old Jun 27, 2001 | 01:24 PM
scauffiel's Avatar
Define "as little money as possible." I've put over $5k into my 383 which makes around 460/460. That is my "little money" - what's yours? Don't think that you'll stick to a budget because you never do. Plan out your engine, get parts cost, then add 40% at least to cover "incidentals" - also known as the "while I'm here I might as well"'s...
Darth Steve
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
