Hard Start
Old Jun 27, 2001 | 09:24 PM
94'_SS's Avatar
Hard Start
88 5.0 TBI Firebird 130,000 miles. When I go to start the car I have to step on the gas to get it started is this normal for these cars? Once started it runs smooth and has great throttle response the only problem is geting it started. Any ideas?
Old Jun 27, 2001 | 09:39 PM
Vader's Avatar
94,
This is not normal. There is a fuel enrichment routine int he PROM programming for starting fuel when the engine is cold.
Very often, having to open the throttle to make starting possible or easier/faster is a sign that the fuel injectors are leaking down after the engine is shut off. You can determine this fairly easily on a TBI car by removing the air cleaner and folding a piece of paper to fit in the TBI directly under the injectors. After you shut the engine off, place the paper under the injectors and wait about 20 minutes. If you see fuel spotting on the paper, your injectors (or one of them) is leaking down. Replacements are common bone-yard items.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 27, 2001 | 10:22 PM
94'_SS's Avatar
Thanks for the help I will check that out. I am also going to change the fuel filter and see if that helps any.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
