May need 350 injectors to help !!!!!!!!!!!!!!!!!!
Old Jun 22, 2001 | 03:09 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
OK I bumped up the Idle now it will keep running......and I got my chip back from Fastchip and the timing is set on 6* BTDC as they suggest. NOW its still backfiring when I hit the gas and still REAL LOW on power...........Do I need 350 injectors?????? I am using the Stock INjectors now with the LT4 cam. When I pull the #1 plug its very black!!!
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
[This message has been edited by Brian Felts (edited June 22, 2001).]
Old Jun 23, 2001 | 02:33 PM
btt
Old Jun 26, 2001 | 11:52 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
what do the spark plugs look like. Have checked or changed your fuel pressure. I would try uping your fuel pressure if the plugs are WHITE. If you feel you need 350 injectors and you might, I might still have a set laying around for $30 shipped for the pair.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar
*Alston SFC's
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
Old Jun 26, 2001 | 02:13 PM
Hey thanks for the reply, however I was way off base. I found the car running very rich!!! I had to back fuel pressure way off. Thanks though
Brian
1989 Camaro RS
Old Jul 1, 2001 | 12:29 AM
JPrevost's Avatar
Car: 91 Red Sled
If the car runs SUPER rich it should still run and miss down low but get better around 2500. When my car was running dog rich it didn't backfire one burp. Well...until the fuel injectors came off and started a little fire (Holley crap). I don't know why the plugs are coming out black. It doesn't make any sence. Are they black after you've had it running at idle for a while? Did you try my little TPS sensor "flick" trick? Does that make the car run worse or better?
, Jon (350 TBI!)
91 Red My website
Old Jul 2, 2001 | 02:07 PM
Jon:
Hey glad to hear from you. Well the car is still bad. I did your TPS trick and it did nothing. I used a friends Auto X-ray and all it would tell me that the computer would not respond. It will not idle and then at times it will, however when i hole the throttle open it will run.......Also you can see the timing jump from 6* BTDC and then go to full advance at only idle. (past 12* BTDC)
Do you think the computer is bad????
Brian
[This message has been edited by Brian Felts (edited July 02, 2001).]
Old Jul 2, 2001 | 11:09 PM
JPrevost's Avatar
Car: 91 Red Sled
This is screaming IGNITION problem. Scrap the MSD for now. Go back to stock setup completely. See if any of this helps. It sounds like a bad ignition system from what you just said about the timing advance. I really doubt the ecm or eprom are bad. The only time the ecm goes bad is when you have a short and then you'll fry the ecm and get that strobe light SES light. I would bet money it isn't the ecm or the eprom, remember we installed my ecm and nothing changed, still irregular, it ran good for a while then bang. Then tried to restart and it didn't, then it did, all FUBAR!!! I'm almost certain it's in the ignitions system. I bet you're getting a faulty ignition code, it doesn't display as an SES light in my car for some reason, but I had that problem when I didn't have something hookedup. E-mail me if you find the ignition to be fine and I have one last plan of attack that can't be talked about on the board.
, Jon (350 TBI!)
91 Red My website
MustangBeater20
Oct 29, 2022 09:20 PM
bamaboy0323
Sep 3, 2015 06:07 AM
xxx3man`
Aug 28, 2015 02:21 PM
Keith5
Aug 27, 2015 04:37 PM
Eric-86sc
Aug 24, 2015 09:01 PM
