Some chip tuning questions
Old Mar 16, 2007 | 07:30 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Engine: 350 Holley TBI Personally Tuned
Transmission: 5 Speed
OK, i had bought all the stuff and started tuning my own chip last spring, and BMmonte helped me out alot, i got the car running good, and go rid of alot of my problems, and this question isnt a real big problem, but i just want to figure it out, before the car warms up to temp, and i start driving it (its a 5 spd) when i get higher in a gear it seems like the car just runs out of engine like when it gets into the 3500-4000 range. Almost like its not getting anymore fuel, but once the car warms up im good, and can run the gears up and down all day long, i feel like i just need to make a fuel adjustment somewhere but im not sure where to do it or how to pin point it. Thanks for your help again guys!
Old Mar 16, 2007 | 08:13 AM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
In the 8746 try the Open Loop AFR vs Temp (location 0xD38B) and Open Loop AFR vs Load (location 0xD344) to adjust AFR prior to going into closed loop.
Old Mar 16, 2007 | 09:14 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
What would i be looking for and what would i be wanting to adjust?
Old Mar 16, 2007 | 12:50 PM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Should I raise the AFR on both of those graphs? how much to increase? and i should only raise the AFR in the sections up to the temperature that i know when the problem goes away? Thanks!
Also could i adjust the choke as well? the CHOKE- AFR subtracted vs coolant
Old Mar 16, 2007 | 02:58 PM
Ronny's Avatar
i believe the choke times out pretty quickly.
on a cold start i can witness with the WB that the A/F changes shortly after car starts. As was stated the OL AF tables vs temp are where to look. my car also is manual. i never adjusted the OL load table however. maybe i should?
Old Mar 27, 2007 | 10:37 AM
xjcamaro89's Avatar
Car: 1989 Camaro RS
Re: Some chip tuning questions
ok, i upped the AFR in the chart listed above and ran the car and it bogged out sooner and worse than it did before, so should i decrease the numbers in the lower temp ranges? which way richens it and which way leans it, and do i have to redo my VE tables after this change also? Thanks!
MustangBeater20
Oct 29, 2022 09:20 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NBrehm
Aug 25, 2015 11:49 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
