More Trouble codes HELP
Old Jul 9, 2001 | 07:04 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Well I am getting closer....I am using a Auto X-ray and I am getting a code 42 Ignition timing monitor ( ican't find that problem)
I am also getting a code 34 Map too low
and code 33 map too high this was a scan from about 50mph in high gear.
How can I get both codes??
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Jul 9, 2001 | 09:27 PM
jase's Avatar
You may need to change the map sensor for those two codes. Check the wires connecting to the map sensor to see if you have a short or if the wire is bare and touching something.
Old Jul 11, 2001 | 11:09 AM
Kyle F's Avatar
What HAppened to the old MAP sensor?
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
