Knock Count and others
Old Jul 12, 2001 | 07:19 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Well I did like Kylef said and got a knock count of 53 at about 4000 rpm and about 3/4 throttle.........Now I went back and did it again and got a knock count of 2........then I go back and put the Auto X-ray on monitor for knock counts and run it easy and hard then nothing changed just 2!!! Getting better but I set the timing to 2*btdc for the measurements. Still low on power.
Also I forgot to add every now and then the idle will jump from 750 to 1200 on its own and will not go back down until I turn the car off.
BRian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
[This message has been edited by Brian Felts (edited July 12, 2001).]
Old Jul 12, 2001 | 08:04 PM
jase's Avatar
Hey Brain. What about your custom chip?Try putting a stock and see if it doesn't improve your power.This is only a thought since your having trouble.
Old Jul 12, 2001 | 08:18 PM
Yes I need to try that. I have had it back to fastchip once and they keep telling me its correct.....I don't know but I hate to keep bugging them.
Brian
1989 Camaro RS
Old Jul 12, 2001 | 08:36 PM
jase's Avatar
Sometimes they will send in a bad chip just to make a quick buck.You've done just about everything and thats got to be near the bottom now.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
