speed driven gear
speed driven gear
How do you change the driven gear of a speedometer. Im going to a 4.10 gear ratio. And I just want to get close to acuurate. I think I'm going to go with a 45 tooth. But how do I change it.
not sure. think the gear mechanism is in the tranny somewhere.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
-Tas
'89 Formula WS-6
:Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
If you are just changing the driven gear, thats not too bad. Just get the car on a lift, then unplug the VSS wiring harness. The VSS is located on the tailshaft housing. It is between the transmission and the driveshaft. You may have to take out the brace that runs the length of the driveshaft, it bolts near the rear end then just pulls out. After you do that you should be able to get to the VSS. Unbolt it and it should slide out, then just replace the gear. It just presses on.
If you have to replace the drive gear, you can get it 100% accurate and It may not be much more work at this point. All you have to do then is unbolt the driveshaft and take off the tailhousing. The basic swaps is covered in detail at this site: http://sethirdgen.org/vss.htm
Make sure you put the pin back on if you do the drive gear or else it will just unseat in about 3 miles..
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
