305 heads
Old Jul 15, 2001 | 12:02 PM
91 RS AGAS's Avatar
305 heads
Can anybody tell me about the difference in the 305 heads.I have seen in some articles that some had a sligtly larger valves and that some where better if it was by year or model or is the only way to tell was by the #on the head? Rich.
Old Jul 15, 2001 | 01:59 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
AFAIK, there is no difference in valve sizes between any third-gen 305. Earlier 305's from the 1970's had smaller valves, but I currently have a set of 1986 LG4 heads in my garage with 1.84/1.50 valves, and the L69 heads off my 1984 L69 were 1.84/1.50 as well. I see no difference between them.
Cylinder heads earlier than 1988 were equipped with non-self aligning rockers and broached pushrod guides, and heads after 1988 (the crossover year) started coming with self-aligning rockers and no broached pushrod guides. Heads from 1987 on up were equipped for centerbolt valve covers. Sometime after 1989 or so, GM started using a swirl-port head that features an unusual bowl under the valve that 'swirls' mixture into the cylinder.
Still, I have seen no differences in any valve size on any 305 head from the 1980's. I think the mythical "305 H.O. head" is just that: A myth.
Daniel Burk
View my third-gen hobbyist performance page!
View my reader's ride!
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New!Full 1LE brake upgrade! Details at website above.
Old Jul 15, 2001 | 03:27 PM
Tas's Avatar
Tas
the 305 TPI heads are better than 305 TBI heads. TBI heads have swirl ports. The TPI don't.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Jul 16, 2001 | 01:12 AM
CHVYPWR's Avatar
Car: 1978 El Camino SS
Transmission: T-5 & 3.73's
Most of the difference is the combustion camber size. I have a set of 305 heads off an '83 carbed "HO"( or high compression) 305, the chamber size is 58cc, casting number 14014416. These have the 1.84" intake and 1.5" exhaust valves. The regular 305 heads are 76cc ( low compression) chamber with 1.73"/ 1.5" valves.
Ya can't have too many fast Chevys!
[This message has been edited by CHVYPWR (edited July 15, 2001).]
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
