I Need To know What Does These Mean & DO
Old Mar 21, 2007 | 01:12 PM
redline_racing's Avatar
hello,I need to know what does these do and what purpose do they serve?305TBI
IAC:
Means and what they do fir the car
TBS:
MAP Sensor:
WHAT DOES THESE DO ??????????THANKS ROB
Old Mar 21, 2007 | 01:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: I Need To know What Does These Mean & DO
IAC = Idle Air Control, a valve to control the amount of air entering the engine at idle and therefore the idle speed.
TBS = Probably should be TPS, Throttle Position Sensor, tells the computer how far open the throttle is.
MAP = Manifold Absolute Pressure sensor, measures air pressure inside the intake to determine engine load.
Old Mar 21, 2007 | 01:43 PM
because I dont know what wrong with mine bad idle slow *** take off leads to stalling and putt ing and I dont know what wrong with it the previous owner rebuilt motor and trans and needed the liittle kinks to be worked out>?
