Running rich and flooding out
Old Mar 15, 2007 | 06:28 PM
Ninety-One's Avatar
Car: 91 LT1 RS 89 IROC-Z 350 TPI
Engine: LT1 // 350 TPI
Transmission: WC T5 // 700R4
Axle/Gears: BW 9 Bolt 3.27 //BW 9 Bolt 2.77
So I took out my fuel injectors and noticed microscopic cracks in the o-rings. i'm going to replace those, but was that really causing all my problems? The car runs so rich it floods and dies VERY often, like i cannot even drive it around. And I'm getting about 2 miles to the gallon. With no fuel leaks. Could my injectors be failing? The car did sit for 6 years... and if they are failing do i rebuild them, buy new or what? I'm really lost right now and kind of fed up of this car right now...any help would really be appreciated.
Old Mar 15, 2007 | 06:39 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
i would probably guess 02 sensor or TPS
or uhmmm something else that reads/deals with throttle position
i dunno
hmm, thats pretty crazy
Old Mar 16, 2007 | 12:17 AM
Ninety-One's Avatar
The TPS is brand new, and works fine. Where is the o2 sensor?
BTW: There's no check engine light on.
Old Mar 19, 2007 | 11:49 PM
cranknrods's Avatar
Car: 92 RS
Engine: 350vortec
my way of fixing things is to fix the easy stuff first-meaning-if you know the o'rings are bad then fix them first. its amazing at how you can fix the little things then the big problems go away.
then check to make sure your timming is right.
it also sounds like it could have a vac leak.
but try the o'rings first then go from thier
Old Mar 21, 2007 | 09:59 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Running rich and flooding out
Its extremly rare for these injectors to fail. They couldve corroded internally, but the usual mode of failure seems to be the internal O-rings blowing out and causing fuel to spew out the top of the injector.
More then likely its a faulty CTS or MAP sensor. Could be a blocked return causing the pump to dead-head, but the stock pump maxes out at around 12 PSI, so its unlikely. A grounded O2 could do it, but it should set a code after some time if the O2 voltage stops swinging.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
