Dual snorkel for the L03
Old Jul 9, 2001 | 03:50 PM
carter89RS's Avatar
does anyone know if the dual snorkel aircleaner from the L69 will fit on the L03?
Old Jul 9, 2001 | 03:51 PM
irocbsa's Avatar
Check your post in the Tech/General engine forum.
bsa
Old Jul 17, 2001 | 09:01 PM
NHcamaro's Avatar
I was told yes but not to sure. I'm going to go to camaro heaven soon and see if they have one. I'm going to be trying it on my car hope it fits ..if not, going to make one
1988 Sport Coupe 305 TBI
K&N
Flowmaster exhaust
Daily driver:
1988 K1500 5.7 4x4 shortbed flowmaster cat-back gutted cat.
Old Jul 18, 2001 | 12:22 AM
Keith5's Avatar
Car: C1500
It will fit if your smog stuff is out of the way.
1989 Pontiac Firebird Formula LO3 Auto
-180 degree stat
-Hooker Cat-Back
-velcro t-top bag
-Wonder Bar from my IROC
Waiting for install: Open element 14x3, 95 vette lt1 cam
*****Possible future mods*****
4th gen seats, fiberglass spoiler, rear disc, 3.42, torsen(posi), Edlebrock Performer TBI intake, headers, y-pipe and cat, afpr
1985 IROC-Z, TPI Auto
-Accel Super Coil
engine and tranny overhauls coming this summer
http://www.geocities.com/krt80/
Old Jul 18, 2001 | 12:27 PM
CODY BEHNKE's Avatar
You don't need to remove your smog stuff to put this on, you just need to move the passenger side snorkel up a little bit. To make it look good get a aftermarket breather and use the H.O. air cleaners breather hole for your air sensor. I used a pcv valve gromet to seal arond it. It looks factory this way, don't relocate you air sensor.
Old Jul 18, 2001 | 09:41 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
The Duel Snorkle fits great.. I did find in order for the passanger duct to fit properly I moved it to a different location. Lucky for me in my situation was I don't have "Air". Here are some pics. As for the sensor, I just drilled out a hole in the new Air Cleaner for it, so it's back in the same place as on the original Air Cleaner.
Here you can see where I moved the Air Diverter for the smog system.
And here you can see where I put the sensor.
I hope the pics work. If not here are some direct links.
http://www.unlimitedlights.com/lo3-1.JPG
http://www.unlimitedlights.com/lo3-2.JPG
http://www.unlimitedlights.com/lo3-3.JPG
89 RS Camaro, LO3 305 TBI
L69 Duel Snorkel Intake
Dynomax Ultra Flo SS Cat Back
[This message has been edited by FastElectrics (edited July 18, 2001).]
Old Jul 18, 2001 | 10:28 PM
Keith5's Avatar
Car: C1500
<font face="Verdana, Arial" size="2">Originally posted by CODY BEHNKE:
You don't need to remove your smog stuff to put this on</font>
I didn't say remove it, I said as long as it's out of the way.
Old Jul 18, 2001 | 11:18 PM
My305camaro's Avatar
Will the dual snokel work if you have A/C?
1991 Chevy Camaro RS TBI
Old Jul 19, 2001 | 01:34 PM
JPrevost's Avatar
Car: 91 Red Sled
When I did this on my 91 I had to unbolt the unit from the smog air pump. So I did have to "remove." I couldn't figure out how to move it out of the way since the pipe coming from the smog pump is solid with a flat face (no adjustments).
I gutted my dual snrk. setup and used large pvc end caps with silicon sealer for the holes left by the Thermac crap. The difference between the stock air cleaner gutted and the dual snorkel is noticable. At least for me it was. Best way to tell is to drive around with no air cleaner (don't forget to hook up the IAT), then run with the stock setup, then the dual snorkel. You should notice a difference if you have slight modifications like I did (headers, full exhaust, 6 deg. advance).
, Jon (350 TBI!)
91 Red My website
Old Jul 19, 2001 | 09:46 PM
carter89RS's Avatar
is the dual snorkel setup better than an open element?
Old Jul 19, 2001 | 11:00 PM
Car: 89 Camaro RS
Engine: 305 TBI
Some would say yes it is, other would say no. If you have a good induction hood, and open element would be good. But for a stock hood I like the snorkles, draws cold air, and at speed has a nice ram air effect. I personally like the Duel Snorkle for the fact that I can draw cold air.. Though the only thing I don't like is how much restriction there is for the air to get to the intake duct. But Since I don't race, it's not that big of a deal.
91 SrS
Oct 7, 2015 04:32 PM
zman1969
Oct 1, 2015 11:09 AM
