RPM going up and down.
Old Jul 23, 2001 | 11:31 AM
manuel's Avatar
My RPM is going nuts. When i have have the car in parked the RPM goes up and down like crazy...and when I stop when in Drive. I changed the TPS,IAC,and M.A.P. sensor...and still does it!!!What can yall recommand to make my idle run better?thanks.
It is not how you stand by your car,but how you race it.
Old Jul 24, 2001 | 04:56 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Depends on your engine type. For TPI I would check our your MAF sensor first. For TBI or carb start with fuel pressure.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Jul 24, 2001 | 05:13 PM
cobrakiller1989's Avatar
I would also check fr some vacuum leaks. When i had one my car would not idle good at all. If you check for leaks and think you might have one spotted, get a can of carb cleaner and spray it in that area. If the car revs slighly when u spray then you have found a vacuum leak
good luck
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4 this summer)
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*NO recent time slips.
Old Jul 24, 2001 | 09:44 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
Is it the guage that is bouncing a lot or is I the engine revig a lot.
If the tach needle is bouncing (you also notice slight surging), then you have some plugs and wires fried.
I don't know it the needle is your problem or not, but I was on mine and 75 dollars and two cut up forarms later it was a new car.
late model 91 rs
fully loaded t-tops, red leather
paint- gm red and yellow blend (light red)
custom painted 16" Camaro rims
305 tbi 14"x3" O.E, computer chip, accel super stock plug wires
Edelbrock 3" cat-back
MTX sub and amp, Bose all around
vic_v8@yahoo.com
street kills: a lot of "family" cars, pickups, New v-6 stang, totally killed '86 SC Camaro, 91 z 28 with 305
Old Jul 25, 2001 | 10:18 AM
manuel's Avatar
Thanks for the tips guys.My car is a '89 305 TBI firebird.I'll that carb cleaner and try for a vacuum leak.Thanks.I keep ya'll posted.
IROCtometal
Sep 20, 2015 11:08 PM
BLK87Z
Sep 18, 2015 11:29 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
