can someone help me
Old Mar 25, 2007 | 09:11 PM
bigal's1991's Avatar
Car: 1991 camaro RS
Engine: currently swapping 5.3
Transmission: 4l60e
Axle/Gears: soon to be 4:11
can someone help me
im 15 and i just started restoreing a 1991 camaro rs with t tops..... i was wondoring, is there a limit to the size cam you can run with a stock computer?..... and if you put a performance chip in would you be able to run a bigger cam
Old Mar 25, 2007 | 11:10 PM
galvarado's Avatar
Car: 88 Camaro SC
Engine: Aluminum Vortec headed 383 roller
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt/3.27
Re: can someone help me
If you go to a bigger cam you can use the stock computer but you have to change the programming. The chip has a .bin file that has your fuel tables, spark tables and lots of other parameters. The bigger you go with the cam the more you have to change your programming. I wouldn't waste money on a "performance" chip. I've heard they aren't much different from stock programming. Before you start modifying your engine you should read the DIY PROM section on this board. Most of your horsepower is going to come from your ability to program chips yourself. I went from a 305 TBI like yours to a 350 vortec with a ZZ4 cam but kept the TBI. The engine ran with the stock tune but it had no power whatsoever. Also, look into the EBL(embedded lockers). How far along are you on the restoration?
Gene
Old Mar 26, 2007 | 08:22 AM
Car: 1991 camaro RS
Transmission: 4l60e
well, right now we are tryin to find the best ways to add power, without spending alot, we don't have any ideal how to burn chips, but were workin on it..... im gettin headers, new flowmaster exhulast, high flow cats and a cold air intake, (that we are makin out of the TPI air intank on the front of a camaro... )
Old Mar 26, 2007 | 01:21 PM
galvarado's Avatar
Car: 88 Camaro SC
What you have planned is a good start and you don't need to burn chips for that. I believe you can also add an intake as well. Edelbrock and Holley manufacture TBI intakes but I hear the Edelbrock is an easier swap because everything hooks up to it nicely without having to adapt anything for it to fit and function.
Gene
