connector at fuel injector
Old Mar 27, 2007 | 12:20 AM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
car was running badly. rough idle, no power, running very poorly. i pulled over to the side of the road and removed the air cleaner lid. i looked at the connectors that attach to the injectors. one connector was firmly seated and locked to the injector the other doesnt clip anymore. it was very loose barely attached. where do i get a replacement connector? in order for the car to run propely it need to be securely attached. when i realized it was loose i pushed it down as tight as i could get it. car ran perfectly after it was propely connected. it still doesnt lock. where do i get a new one? car is a 1989 camaro RS L03 305 TBI.
Old Mar 27, 2007 | 10:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: connector at fuel injector
You could try a NAPA store, they carry a bunch of connectors.
Otherwise a junkyard. If the pins are OK it is easy to swap the connector housing. There is a little tab on each pin that holds it in place. Carefully depress the tab and the pin slides out.
RBob.
bryan623
Mar 22, 2021 06:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
