How much Horse power would edlebrock headers & y-pipe with 3" exhaust piping with no cat free up?
I’m going to install that setup here next week when the exhaust shows up along with some 3.42s I got last week. I’m hoping to get in the 15's considering my best time stock with open element is a 16.170 any one want to take a wild guess at what my new time might be? I’m going to start doing some chip tuning as soon as I get my data logger to work
In short a lo3 with Exhaust 3.42's with chip tuning with a best time of 16.170 stock what do you think it will run?
I'd say about a 15.5- 15.7 at about 90 mph or so. Maybe slightly quicker with dead on tuning and a little weight reduction. You should try some of the cheap n easy mods like the TB coolant bypass, smog pump removal, advanced timing or try and fab up a dual snorkle intake.
I have yet to run my car with my 3.42's and headers, back exhaust but my totally stock run was 16.07 @ 84.4 mph. thats with 2.73 gears stock posi. and restrictive exhaust. i ran my car on the dyno yesterday and got 157hp and 233tq at the wheels.
in 92 rs with a Lo3, headers, offroad y and flowmaster catback i was doin 15.4@90 with stock 2.73 gears so you should deff be in the low to mid 15s with your set up
TB coolant bypass on a tbi motor?
the TB bypass is a common mod for TPI cars. coolant doesnt flow the TB on TBI cars
I ran a 15.8 with a edelbrock cat back, and open element
I've got 3.23's open diff, 245/50R16's, Hedman Headers w/ 2.5" y-pipe and full mandel bent w/ deleted cat. My Personal best was 15.9292 @86.99 w/ 155K on a stock engine. I fell asleep at the tree all day, gettin used to the stage 1 clutch and I could NOT hookup in 1st.
I'm curious what it'll run but I'd guess-timate mid 15's. Any trans mods? shift kit etc? 700R4's are junk, ... but cheap & built for economy. Be gentle at first.
yea it has a b&m shift kit in it, the tranny slips into third with anything less than full throttle. i will post up my new times after i get my exhaust & gears in next week. the chip tuning wont happen for awhile because of datalogger problems
as soon as i find a used tbi nitrous kit that will be going in also anyone know how long a l03 might last with a 125 shot?
as soon as i find a used tbi nitrous kit that will be going in also anyone know how long a l03 might last with a 125 shot?Supreme Member
If you aren't into 15's with a 3.42 rear and full exhaust, there are bigger problems. I would guess something like a 5 second reaction time or some such.
Quote:
Yeah Your right! My bad! How bout I just give myself one of these... Originally Posted by UnderCover89TBI
For the misleading info and We'll call it even....
there wont be anymore 1/4 mile runs for my l03... it developed a huge knock tonight shes done . bad thing about it is im 16 and i dont have much money and now my only transportaitoin is a ninja 250... Yippie this will be a great summer
on the up side Now i can get a 350 yea!
well at work today I had are mechanic there look at the motor he told me it was the lifter or a bent valve or I couple of other thing he said probably not worth fixing it,
anyway after work I was driving home from the body shop about a 4 mile drive and then I here a sound some what like firecrackers and popcorn going off at the same time
then it died about 1 mile away from home so I called my boss and he pulled it home with the tow truck
Ok Now to get to the point
Here’s a few engines I thought about swapping in let me know what you guys think about them
http://www.jegs.com/webapp/wcs/store...55609_-1_10763
http://www.jegs.com/webapp/wcs/store...52506_-1_10763
How hard would it be to get my tbi system running on this motor? Or would I be better off with a carburetor setup?
then it died about 1 mile away from home so I called my boss and he pulled it home with the tow truckOk Now to get to the point
Fast355
close
- Join DateJan 2005
- LocationHurst, Texas
- iTrader Positive Feedback100
- iTrader Feedback Score(2)
- Car1983 G20 Chevy
- Engine305 TPI
- Transmission4L60
- Axle/Gears14 bolt with 3.07 gears
- Liked:500 Times in 428 Posts
I would go with the 260 HP engine and install a 204/214 @ .050" duration camshaft in it. It will make about 285 HP/350 TQ with headers, an efficient exhaust system, and proper tuning on the intake side. Installed in a car with catalytic converter, etc. it will easily drop down to about 250 Net HP.
204/214* @ .050 is enough cam to pull well up to about 5,000 rpm in a mild 350, yet tame enough to tune easily and get good mileage.
I would suggest checking with a local machine shop. Find out what it would cost for you to drop off a rebuildable 350 and have them go through it. You might be surprised how much money you can save.
You might also look into a reman engine from a parts store, be warned though I've heard some horror stories of engines eating them selfs in a few thousand miles. Luckily they come with warranty's so you won't be out much other than some time swaping the motor.
There are several cheaper ways to get an engine than a GM crate motor.
I did low 15's with mostly bolt ons and 3.23 posi. I probably could have gotten faster but some car dumperd his motor 30min before the track closed and they shut it down. I sold the car a month later but I'd swear if I'd had a better launch I would have hit 15.00 that day. You can easily get that car into the 15's
89 rs camaro 350 tbi auto 3.08 gears camshaft, eddy headers, kn filter, sloppy transmission 14.78 at 92.9 MPH.
i just picked up a 93 lt1 with 56000 for $750 it should put me far past the 15's
Quote:
reaction times dont affect e.t.Originally Posted by Cadillac
Quote:
I was being silly but I am sure at this point you think I am a crack smoker. I deserve that perception sometimes.Originally Posted by UnderCover89TBI
reaction times dont affect e.t. Supreme Member
i do not think you ar ea crack smoker your a bay arear and you dont know what you talking about..lol jp
