tbi hookup problem...fixing throttle linkage connector
Old Aug 16, 2001 | 04:28 PM
killer89transam's Avatar
(when looking at the tbi and throttle linkage from the front of the car)The bottom cable which connects to the throttle body(has a small black end)has broken and needs to be replaced. How hard is it to do this and where can i find the part. Just a junkyard or can it be found somewhere else. Thanks for the help guys.
Old Aug 16, 2001 | 04:30 PM
The shift points and rpms are shifting correctly right now. Is there any harm of driving it without the cable really hooked up until it is fixed. I plan on fixin asap though. As soon as i find out that is. Thanks again.
Old Aug 16, 2001 | 09:35 PM
steve8586iroc's Avatar
If your talking about the tv cable that connects to the transmisson then don't drive it till you can fix it. It will take out your trany and you will have to have it rebuilt. Be vary careful and make sure you adjust it correctly.
Old Aug 17, 2001 | 01:12 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
local dealer will get you your part. go to the door that says. "parts" on it.
92camaroJoe
Jul 29, 2023 07:57 PM
pimp2303
Jul 27, 2017 02:03 PM
Jote4805
Aug 25, 2015 06:11 PM
perZ
Aug 15, 2015 01:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
