Is there a crossfire guide anywhere?
Old Apr 3, 2007 | 01:13 AM
ndamron's Avatar
Car: 82 Trans-Am / 83 Trans-Am
Engine: Major Mod SBC / Minor Mod SBC
Transmission: Major Overhaul 700R4 / Stock 700R4
Axle/Gears: None!!! / 3.73 posi disc...soon
I'm looking for more information about common problems with the crossfire system so i can repair mine.
~Nick~
Old Apr 3, 2007 | 07:12 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Re: Is there a crossfire guide anywhere?
Crossfire is just a different version of TBI, using 2 throttrle bodies instead of 1. The factory service manual is what you need; you also want to look up the Crossfire Vault website in addition to this one.
http://www.crossfire.webhop.net/
Finally posting the symptoms of your car's problem(s) would help, along with you doing a search. Most of the problem-questions have already been asked & answered here before, you just need to spend the time to find the answers.
Old Apr 6, 2007 | 11:04 PM
jase's Avatar
whats wrong with it?
Old Apr 6, 2007 | 11:07 PM
ndamron's Avatar
when i start the car it idles at 1500 rpm until it warms up, it then fluctuates from 450rpm to 800rpm, after driving for a while i have to step on the gas and the brake at the same time so it doesnt die out. While driving the car runs fine. I am not getting any codes. I dont know what to do.
~Nick~
Old Apr 7, 2007 | 06:36 AM
kdrolt's Avatar
Engine: LO3, LO5
Do a search here using: IAC + idle + uneven
There are other things that can cause an uneven idle (clogged fuel filter, weak ignition, et al.) but a dirty IAC is probably one of the most common. Also search on the CFI Vault (CFI = Cross Fire Injection).
Old Apr 7, 2007 | 07:15 AM
simo's Avatar
Car: 1983 Daytona 500 Pace Car
Engine: CFI - 305
Transmission: Automatic-700R4
Try this:
Check your ground wire inside your HEI Distributor from the ignition module to the grounding point, this tends to get rusty and has a high resistance.
Disconnect and clean the grounding ring and ground area.
Old Apr 7, 2007 | 06:59 PM
86FireBird305's Avatar
Car: 1986 Firebird LG4
Engine: 305 5.0 LG4
Transmission: TH-700R4
crossfire injection sounds pretty cool but i hear it has alot of issues over time
Old Apr 7, 2007 | 08:09 PM
ndamron's Avatar
yes they are neat, usually it's a stupid problem that you over look and are like....oh yea....i should have thought of that off the bat.
~Nick~
Bubbajones_ya
Oct 25, 2015 08:01 PM
NZKnight
Oct 15, 2015 02:47 PM
sandman92084
Sep 12, 2015 10:27 PM
edoff13
Sep 11, 2015 03:55 AM
