What size are the injectors from the 4/6 cyl.
Old Aug 19, 2001 | 12:51 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I see many 4 and 6 cyl cars with TBI in the bone yard.
What are the chances these are the same as an L03?
Mark.
Old Aug 19, 2001 | 05:52 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
i bet they are smaller. but then again they are the one injector setups so they could be the same. however, i cant imagine anybody actually knowing the answer to that question unless they have an injector flow bench and have tested them.
Old Aug 19, 2001 | 07:17 PM
Mark_ZZ3's Avatar
Engine: TPI(s)
I found a set of injectors today from cadilac. Not sure of any color bands, but I can read the number on them, #GM61906 ... Any ideas?
Most caddy engines where 400+ cubes, so I am curious as to what injectors these are.
I figure the 2.8L single injectors are probably as big as each of the injectors on the 305's ... at least cuic inchly speaking.
I do know someone with a flow bench. So if I have to get a set cleaned, I may get a few flowed.
Mark.
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
knight72
Aug 10, 2015 09:32 PM
