Removed A.I.R. any tips?
Old Aug 18, 2001 | 10:52 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
Installed the L69 dual snorkle air cleaner.Got pretty frustrated with trying to relocate the
damn thing (A.I.R.. injection) I just ripped it outta there.
Car seems to run stronger and is louder but now I get a check engine light after a few minutes. Any advice as to the ramifications of my hasty (?) choice?
Should I plug up any holes? thanks
88 TBI IROC- mods- 5500 rpm redline tach, 240 KM/H speedo,
L69 air cleaner (installed someday
[This message has been edited by 871LEIroc (edited August 18, 2001).]
Old Aug 19, 2001 | 01:49 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
It shouldn't be throwing codes if you plugged everything up right. I'm assuming you didn't from the wording of your post. The metal pipe leading to the cat oughta be plugged or removed. and get some 1/4" pipe plugs from depot for each hole, otherwise the car'll suffer
the second part's only from my experience a month ago when i removed my AIR. car ran like sh*t in the garage until i plugged all the holes in the exhaust manifold.
http://www.tcnj.edu/~esposit3
https://www.thirdgen.org/rides/index...ew&rideid=1137
Member of FBS
AOL IM Name: JimmyTime5
  • '89 Trans AM, 305 TPI, 5-spd
  • '86 Firebird, 2.8, Auto
Old Aug 19, 2001 | 08:20 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
You didn't plug all the holes in the manifolds?! LOL! That musta sounded pretty bad! Reminds me of the time when my friend forgot to bolt the manifolds up to his engine, he just started it up, BIG MISTAKE!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
89 formula TPI
Sep 8, 2015 08:00 PM
L0tuS
Sep 4, 2015 11:16 PM
